查看: 312|回复: 15
No more cat scale
 楼主| 发表于 2019-6-10 01:41:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1000.0,\"name\":\"\",\"url\":\"\",\"width\":750.0}]","canComment":true}
发表于 2019-6-10 04:42:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"My freightliner has the same thing, but no way would I risk not scaling my whole rig out, it’s better to cover your bum if ya know what I mean","replyToPid":0}
发表于 2019-6-10 10:27:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"you are an idiot, that is to lower your air bags on the drive  hehehehehe","replyToPid":0}
发表于 2019-6-10 01:49:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"How does that work ? So it gives you the weight of the whole trailer? I move brand new trailers from the Manufacturer and some have a scale attachmented that gives you the the weight of the load.","replyToPid":0}
 楼主| 发表于 2019-6-12 00:34:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂","replyToPid":63631}
发表于 2019-6-12 00:08:10 来自手机 | 显示全部楼层
607385 发表于 2019-06-09 17:56:44 what kind of truck is that??
","text":"a Transformer jk 😁","replyToPid":60872}
发表于 2019-6-11 01:40:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your finger is dirty!","replyToPid":0}
发表于 2019-6-10 04:44:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I bet you'd all be amazed by sliced bread.","replyToPid":0}
发表于 2019-6-10 03:31:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"interestin'.","replyToPid":0}
发表于 2019-6-10 03:37:57 来自手机 | 显示全部楼层
711455 发表于 2019-06-09 17:49:01 How does that work ? So it gives you the weight of the whole trailer? I move brand new trailers from the Manufacturer and some have a scale attachmented that gives you the the weight of the load.
","text":"Just the weight on the drives. Some trailers have their own gauge.","replyToPid":60869}
发表于 2019-6-10 03:40:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh ok 👍","replyToPid":0}
发表于 2019-6-10 10:37:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont trust it. mine is off 1800 lbs one load and could be 1200 off on the next. use it as a ballpark guess at best.","replyToPid":0}
GMT+8, 2026-2-6 12:39 , Processed in 0.077337 second(s), 24 queries .
