查看: 706|回复: 15
How to fix this?
 楼主| 发表于 2022-8-12 05:31:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"I almost didn’t scale because they said 32k weight but it felt too heavy. They told me they would take off 1,180 lbs but I’m already in the 12th hole so I think they need to readjust the load as well. Now I have to wait another day because the shippers went home what do you think?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":321.0,\"name\":\"\",\"url\":\"\",\"width\":695.0}]","canComment":true,"externalShare":false}
发表于 2022-8-13 05:34:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ll give you the straight forward answer; you cannot fix it. You’re only allowed 80,000 gross total. Period. If you were over 1,000 on your Axels and under gross , then yeah… it could be fixed. Don’t go over 80k or you may be unloading it by hand at a weigh station. These trucks are designed to carry 80k. Anything heavier needs a permit. Why would you want to add someone else’s greed and you not get paid as much and risk your career? Ask yourself risk vs reward. ","replyToPid":0}
回复 支持 12 反对 1
发表于 2022-8-12 18:23:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I make them rework that load and I supervise them because I am extremely picky about I'm loaded, I also warn them if it's loaded wrong they're paying the ticket","replyToPid":0}
回复 支持 7 反对 0
发表于 2022-8-12 13:35:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re not going where the 40 foot law is in effect, slide it 2 holes back and drive on. 🤙🏼","replyToPid":0}
回复 支持 4 反对 1
发表于 2022-8-13 10:57:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make them rework it don’t risk your safety brother. Stay safe ","replyToPid":0}
发表于 2022-8-12 21:24:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure you get paid for lay over time or refuse the load. You’re losing money sitting there all weekend ","replyToPid":0}
发表于 2022-8-13 02:55:47 来自手机 | 显示全部楼层
654350 发表于 2022-08-12 05:35:49 If you’re not going where the 40 foot law is in effect, slide it 2 holes back and drive on. 🤙🏼
","text":"bridge laws are not pressed unless you're going downtown Chicago or in California hole positions don't matter as long as the weights are legal","replyToPid":466114}
发表于 2022-8-12 21:44:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Where’s your layover at? I can dispatch one of my old dried up trucker gals to clean your truck and try to convince you they are your equals. ","replyToPid":0}
发表于 2022-8-12 23:42:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Start Haulin Cattle, then you don't have to worry about it. just kiddin,  make them fix it.","replyToPid":0}
发表于 2022-8-12 19:38:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is a test. First and Foremost. I hope you pass.","replyToPid":0}
发表于 2022-8-13 04:39:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"at a beer distribution plant I asked for a rebalance because I couldn't 7th hole. boy, that guy was mad. but the receiver was a super tiny local distributor and 7th hole was the only way I could hard right around their telephone pole almost in the drive. I'm glad I did it. I don't cry about not being back.","replyToPid":0}
GMT+8, 2026-4-17 08:15 , Processed in 0.171503 second(s), 24 queries .
