查看: 509|回复: 24
Good headset?
 楼主| 发表于 2022-8-2 22:09:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"any idea what a good truck or headset would be? I used to have a Rand McNally. I had the most expensive one they had and it lasted three or four months. There’s no way I’m spending $400 on another headset unless it’s actually meant to last.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-8-2 22:28:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"BlueParrott B450-XT","replyToPid":0}
发表于 2022-8-4 10:04:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bluparrot b250 one of the best and cheap ","replyToPid":0}
发表于 2022-8-8 10:16:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"The voyager works really well for noise canceling and lasted about 5 years before I had to replace it for $200- I think they’re under $100 now though and work with android and Apple phones ","replyToPid":0}
发表于 2022-8-2 23:58:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bluetooth radio.","replyToPid":0}
发表于 2022-8-3 07:29:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Blue parrot good choice ","replyToPid":465772}
发表于 2022-8-2 22:33:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"EKSA H1-B02 model been using it 6mths & its Great love it ! like it better than the BP & it's only $80 hope this helps goodluck","replyToPid":0}
发表于 2022-8-3 11:14:15 来自手机
{"replyTo":"","text":"I use astrobùttfùck 2000 it is very good headset for fággot like yourself best of luck girl hope you have a great pèriod! 😃","replyToPid":0}
支持 1 反对 0
发表于 2022-8-3 15:38:26 来自手机 | 显示全部楼层
937661 发表于 2022-08-03 01:30:14 I want one with double ears, and noise cancellation
","text":"word of caution, some states/prov you cannot have both ears covered unless it is hearing protection","replyToPid":465805}
发表于 2022-8-7 07:08:01 来自手机 | 显示全部楼层
1024394 发表于 2022-08-03 07:38:26 word of caution, some states/prov you cannot have both ears covered unless it is hearing protection
","text":"I have a 1 ear but set for the right side so I can hear out of the window, I use the double when I'm doing laundry or shopping only, I also have a visor clip Bluetooth I use if I don't feel like using the headset, I'm 100% against having both ears covered up it's not safe because you lose all concentration on the road and your surroundings","replyToPid":465819}
发表于 2022-8-5 03:17:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any of the Blue Parrott even the original 250 model is perfect clear ","replyToPid":0}
发表于 2022-8-3 03:51:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I really like the Rand Mcnally the CD220","replyToPid":0}
发表于 2022-8-3 05:10:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is the one I’ve had for going on 5 years and it still works great. ","replyToPid":465772}
发表于 2022-8-3 06:35:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Plantronics, ear piece, had for years","replyToPid":0}
 楼主| 发表于 2022-8-3 09:29:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"does it have both sides of the ears? ","replyToPid":465772}
 楼主| 发表于 2022-8-3 09:29:44 来自手机 | 显示全部楼层
367955 发表于 2022-08-02 19:51:25 I really like the Rand Mcnally the CD220
","text":"Rand Mcnally has already failed me and I ain’t spending 400 on another of their headsets. ","replyToPid":465778}
GMT+8, 2026-4-18 19:05 , Processed in 0.163328 second(s), 24 queries .
