查看: 280|回复: 9
how app work?
 楼主| 发表于 2022-8-1 23:50:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"how do use it to find the truckstop","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-8-2 04:17:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here’s your sign ","replyToPid":0}
 楼主| 发表于 2022-8-2 01:01:14 来自手机 | 显示全部楼层
1272475 发表于 2022-08-01 16:48:17 It’s actually pretty simple.  Anything that you see a T on is a truckstop.  Be careful and research as always because some “T” are not always truckstops.  I mainly stick to Loves, Pilot/Flying J, Petro, TA, Etc.  Just makes it less confusing.
","text":"sorry, don’t understand can you pls explain ","replyToPid":465732}
发表于 2022-8-4 09:07:39 来自手机 | 显示全部楼层
{"replyToPid":465881,"replyTo":"
1309412 发表于 2022-08-04 01:01:25 This comment has been deleted
","text":"☻️"}
发表于 2022-8-4 09:01:25 来自手机
{"replyTo":"","text":"Tell your company your a morons and need some to teach you English","replyToPid":465736}
支持 1 反对 1
 楼主| 发表于 2022-8-4 09:47:45 来自手机
","text":"Your mom teaches English "}
支持 1 反对 1
发表于 2022-8-2 00:48:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s actually pretty simple.  Anything that you see a T on is a truckstop.  Be careful and research as always because some “T” are not always truckstops.  I mainly stick to Loves, Pilot/Flying J, Petro, TA, Etc.  Just makes it less confusing.","replyToPid":0}
发表于 2022-8-2 03:38:29 来自手机 | 显示全部楼层
1594841 发表于 2022-08-01 17:01:14 sorry, don’t understand can you pls explain
","text":"I hope you are not a truck driver asking that question ","replyToPid":465733}
 楼主| 发表于 2022-8-2 03:50:35 来自手机 | 显示全部楼层
1228228 发表于 2022-08-01 19:38:29 I hope you are not a truck driver asking that question
","text":"You do? 🥹","replyToPid":465735}
发表于 2022-8-12 12:28:34 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I found some videos on YouTube that you can watch. I’ll try to attach a couple:\n\nhttps://youtu.be/47S7Y6zKejc\n\n\nhttps://youtu.be/EIs5Rk6xpm4\n\nAlso: there’s a User’s Manual in the app. Click on the Me icon on the bottom to get to it. "}
发表于 2022-8-30 08:51:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"go to settings pick the   truckstops weigh scales: whatever and when you punch in your destination they'll show up on your route","replyToPid":0}
GMT+8, 2026-2-6 10:19 , Processed in 0.090065 second(s), 24 queries .
