查看: 191|回复: 3
best route to take
 楼主| 发表于 2022-7-22 04:49:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"what is the best route to take to avoid the steep grades between Vaughn NM and Tuscon AZ? my truck is getting a bit warm.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-7-22 05:22:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"US 54 to Us70 .. you’ll hop up on I-10 from las cruces, NM. All truck route. You might have few small hills here and there. But not too shabby ","replyToPid":0}
发表于 2022-7-22 08:45:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't run your air conditioning while climbing steep hills and your truck won't over heat, all steep grades I just open up the windows and crank on the defrost on high heat, I can't explain the mathematical measures on how it works but it does","replyToPid":0}
发表于 2022-7-23 15:40:46 来自手机 | 显示全部楼层
1248444 发表于 2022-07-22 00:45:30 don't run your air conditioning while climbing steep hills and your truck won't over heat, all steep grades I just open up the windows and crank on the defrost on high heat, I can't explain the mathematical measures on how it works but it does
","text":"Defrost turns on the AC. It's set to do that so the system cycles during cold weather. Turn it on and watch the AC clutch engage","replyToPid":465249}
GMT+8, 2026-3-21 08:13 , Processed in 0.094030 second(s), 24 queries .
