查看: 94|回复: 4
Good morning all and as always stay safe and prosperous ‼️ 👍 🦕 🇺🇸 🗽
 楼主| 发表于 2022-7-20 20:42:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"The coffee ☕️ is in the cup ☕️ ‼️ \n\nEducation is more than schooling.  It is a cast of mind, a willingness to see the world with an endless sense of curiosity and wonder.  If you would be truly educated, you must adopt this cast of mind.  You must open yourself to the richness of your everyday experience--to your own emotions, to the movements of the heavens and the languages of birds, to the privations and successes of people in other lands and other times, to the artistry in the hands of the mechanic and the typist and the child.  There is no limit to the learning that appears before us.  It is enough to fill us each day a thousand times over.Questions to consider:\n\nHow do you choose to see the various aspects of your life?  Lights, television, radio, DVD players--are they sources of wonder, or just everyday things?\n\nIf you were to change anything about your perspective, what would it be?  How would you change it?\n\nWhy are we so prone to take things for granted and stop noticing wonderful things?  What can we do to battle this tendency?\nFor further thought:\n\nReal education should educate us out of self into something far finer--into a selflessness which links us with all humanity.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-7-21 06:29:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh pete if only you were real! 😍","replyToPid":0}
回复 支持 2 反对 4
发表于 2022-7-22 10:34:21 来自手机
1586756 发表于 2022-07-21 20:20:40 oh if only I could cut and paste my life!
","text":"bacooćk","replyToPid":465229}
支持 2 反对 1
发表于 2022-7-22 04:20:40 来自手机 | 显示全部楼层
766797 发表于 2022-07-21 17:35:03 if you be real atleast 50% of me your life would be much better 👍🦕🇺🇸
","text":"oh if only I could cut and paste my life!","replyToPid":465225}
 楼主| 发表于 2022-7-22 01:35:03 来自手机 | 显示全部楼层
1586756 发表于 2022-07-20 22:29:46 Oh pete if only you were real! 😍
","text":"if you be real atleast 50% of me your life would be much better 👍🦕🇺🇸","replyToPid":465153}
 楼主| 发表于 2022-7-22 09:32:38 来自手机 | 显示全部楼层
","text":"...then you get nowhere","replyToPid":465229}
GMT+8, 2026-2-6 11:47 , Processed in 0.061013 second(s), 24 queries .
