查看: 50|回复: 4
Good morning all and as always stay safe and prosperous ‼️ 👍 🦕 🇺🇸 🗽
 楼主| 发表于 2022-7-19 21:30:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"The coffee ☕️ is in the cup ☕️ ‼️ \n\nToday's quotation:\n\nLife is difficult.  This is a great truth, one of the greatest truths.  It is a  great truth because once we truly see this truth, we transcend it.  Once we truly know that life is difficult--once we truly know and accept it--then life is no longer difficult.  Because once it is accepted, the fact that life is difficult no longer matters.\nQuestions to consider:\nHow do you see difficulties in your life?  Do you accept them as learning or teaching situations or wish they would go away?\n\nWhat would your life be like if you had no more difficulties?  Would it be a positive change, or a negative one?\n\nHave you grown more as a person when dealing with difficulties or when life has been flowing smoothly?\n\nFor further thought:\n\nSometimes things which at the moment may be perceived as obstacles--and actually be obstacles, difficulties, or drawbacks--can in the long run result in some good end which would not have occurred if it had not been for the obstacle.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-7-19 22:17:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good morning Pete!","replyToPid":0}
发表于 2022-7-19 22:47:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good post!","replyToPid":0}
 楼主| 发表于 2022-7-19 22:23:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks good morning to you to 🦕🦕🦕‼️🇺🇸","replyToPid":465091}
 楼主| 发表于 2022-7-20 00:19:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you ‼️ ‼️🇺🇸🦕🦕🦕","replyToPid":465093}
GMT+8, 2026-2-6 13:17 , Processed in 1.066123 second(s), 24 queries .
