查看: 402|回复: 8
Fuel injectors
 楼主| 发表于 2022-6-25 05:23:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"Ok guys.  I need some advice. \n\nMy truck has been in the shop for over a week.  I’m starting to get a lil bit worried. He finally got the parts needed from Cummins but today he told me that he believes my fuel injectors need scrubbed out. He said he actually needed extra help and if I wanted to earn some side $ he’d hire me.  Even said we could talk about it over a few drinks.  So I went with him to the bar next to his shop. \n\nSo he said scrubbing my fuel injectors is a process that could be enjoyable if done correctly. But if I use the wrong tools, like if it was too big, it might send me into limp mode.  Which means my truck will be moving around funny until it recovers.  \n\nHe said if the tool is too small,  then the job won’t get done.  \n\nIf it’s the perfect size, then you will know.  The gasket will pretty much explode, which is what you want to happen.  That sends the truck into peak performance.  \n\nI asked him why I would ever want to use the wrong tool?  Like why isn’t there just the one correct size and he explained that sometimes they use the wrong size because all customers are different.  Some pay more for limp mode.  \n\nI asked how much each pays and he said he can calculate the fees once I’ve thought about it and decided if I want to do it or not.  \n\nSo, should I become a professional fuel injector scrubber for some side $?   ","videos":"[]","link":"{}","pics":"[]","canComment":false,"externalShare":false}
发表于 2022-6-25 06:48:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who wouldn't hire a hot 47 yrold redhead grandma with a vāgina from birth from Southern Missouri?","replyToPid":0}
 楼主| 发表于 2022-6-25 06:53:46 来自手机
1529073 发表于 2022-06-24 22:48:41 Who wouldn't hire a hot 47 yrold redhead grandma with a vāgina from birth from Southern Missouri?
","text":"😂😂😂 48 but not a redhead……","replyToPid":464250}
支持 2 反对 0
发表于 2022-6-25 13:00:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok I’m hoping your mechanic did not say any of this and if he did you might want to find a real mechanic cause there is no such process ","replyToPid":0}
发表于 2022-6-25 11:18:26 来自手机
{"replyTo":"","text":"You’ve got to be kidding, right? Just what Kind of “tool” are you talking about?? I mean, you did say you went to the bar with him… Nothing in your post made sense, on both diction and reality. ","replyToPid":0}
支持 0 反对 1
26
 楼主| 发表于 2022-6-25 11:29:09 来自手机 | 显示全部楼层
{"replyToPid":464261,"replyTo":"
17464 发表于 2022-06-25 03:18:26 This comment has been deleted
","text":"😂😂😂😂😂 priceless response…."}
发表于 2022-6-25 23:25:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ya that’s funny","replyToPid":0}
发表于 2022-7-3 08:08:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"sounds like he was tryna use his tool to scrub you just right honey J's.","replyToPid":0}
 楼主| 发表于 2022-6-25 05:33:59 来自手机 | 显示全部楼层
877910 发表于 2022-06-24 21:26:20 😳😂 i got the perfect tool for that😂
","text":"Well, you gonna train me for this side job? ","replyToPid":464243}
 楼主| 发表于 2022-6-25 13:28:58 来自手机 | 显示全部楼层
674413 发表于 2022-06-25 05:00:03 Ok I’m hoping your mechanic did not say any of this and if he did you might want to find a real mechanic cause there is no such process
","text":"😂😂😂😂","replyToPid":464263}
 楼主| 发表于 2022-7-3 08:16:43 来自手机 | 显示全部楼层
1028729 发表于 2022-07-03 00:08:10 sounds like he was tryna use his tool to scrub you just right honey J's.
","text":"Well of course he was….😂","replyToPid":464615}
GMT+8, 2026-4-17 09:30 , Processed in 0.087980 second(s), 24 queries .
