查看: 338|回复: 5
Im new to Qualcomm. Any help or suggestions?
 楼主| 发表于 2022-6-21 09:21:30 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-6-22 07:25:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"open the window and let it fly‼️🇺🇸🦕🦕🦕","replyToPid":0}
回复 支持 5 反对 1
发表于 2022-6-22 11:16:59 来自手机
{"replyTo":"","text":"Pour duck sauce on it and vote BLUE!!!! 🌈👳🏽‍♂️👌🏾","replyToPid":0}
支持 1 反对 1
发表于 2022-6-22 01:35:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"The problem is, there are so many different set ups from one company to another that canned messages are not going to be the same. I recommend pulling each one up and reading it. Ask more specific questions if you need clarification.","replyToPid":0}
发表于 2022-6-23 07:19:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Read the manual. ","replyToPid":0}
发表于 2022-6-23 12:00:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Transflo is a very reliable service, we quit using Qualcomm due to the constant problems and the cost","replyToPid":0}
发表于 2022-9-3 09:11:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’ll get it! It just takes getting used to! As far as using it, it depends on what format the company uses! The last two companies I worked for phased out the Qualcomm and use a tablet! \n\nEither way always push the arrive button when you arrive at a shipper and depart button when you leave a shipper! You can also search “Qualcomm YouTube” or something like that! I’m sure there’s videos on how to use a Qualcomm! ","replyToPid":0}
GMT+8, 2026-4-18 02:52 , Processed in 0.112302 second(s), 24 queries .
