查看: 223|回复: 9
Trying to beat the heat..
 楼主| 发表于 2022-6-19 07:49:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I'm in a 2018 Kenworth T680 and just recently found out that I don't have a APU and instead have to to use my Espar bunk heater which is bad because apparently I have to run the truck to actually use it, does anyone have any tips on how to keep my truck cool?\n\nThanks and be safe everyone!!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-6-24 00:31:45 来自手机 | 显示全部楼层
1532238 发表于 2022-06-23 04:08:23 When I was company driver and had a 2020 t680, our company said they used a gallon every 30 minutes.  No idea if that’s correct.  They didn’t want us idling.  Of course we also had daycabs and that might be different than a sleeper.
","text":"old trucks Like ours are gallon an hour or so.","replyToPid":464108}
发表于 2022-6-24 00:32:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"reread your post. beating the heat with espar heater?? it only heats no a/c.","replyToPid":0}
发表于 2022-6-24 10:07:51 来自手机 | 显示全部楼层
1529073 发表于 2022-06-23 16:31:45 old trucks Like ours are gallon an hour or so.
","text":"I’d pay that much to be able to sleep in comfort ","replyToPid":464136}
发表于 2022-6-24 10:18:29 来自手机
{"replyTo":"","text":"WTF is this guy talking about.  Espar heater is a heater.","replyToPid":0}
支持 1 反对 0
26
发表于 2022-6-23 12:08:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"When I was company driver and had a 2020 t680, our company said they used a gallon every 30 minutes.  No idea if that’s correct.  They didn’t want us idling.  Of course we also had daycabs and that might be different than a sleeper. "}
1万
发表于 2022-6-23 12:02:32 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"how can you \"just find out that you don't have a APU\" ??? \nyou either have one or you don't...\nhere's a tip, open the window..."}
发表于 2022-7-31 01:19:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a room and make your company pay for it. Or is it a room, idle or quite.. ","replyToPid":0}
发表于 2022-7-8 08:45:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need to leave that Company. That’s cruel to not have APU and don’t let you idle the truck ","replyToPid":0}
发表于 2022-7-19 08:02:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"my 18 t680 dashboard says 0.6 gal/hr at 650 rpm","replyToPid":0}
GMT+8, 2026-4-17 06:36 , Processed in 0.114479 second(s), 24 queries .
