查看: 430|回复: 8
Drivers! Don’t forget that tomorrow is Juneteenth!
 楼主| 发表于 2022-6-19 07:28:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Be sure to celebrate by parking your tractor trailer in the entrance or exit to the truckstop. If these areas are already occupied by other “celebrators”, you can park at the fuel pumps, on the scale, or just block a bunch of drivers in, it will be YOUR day. Every day is YOUR day, because it’s all about YOU!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-6-19 08:35:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also make sure you drive through the lot at 40 mph.","replyToPid":0}
回复 支持 9 反对 2
1万
发表于 2022-6-20 00:06:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's Father's Day today... \nHappy Father's Day to all the father's out there... \n👍 🇺🇸 🙂","replyToPid":0}
回复 支持 8 反对 1
发表于 2022-6-19 07:34:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Also make sure you open your door and dump out whatever trash you may have on the ground before you leave the truck stop in the morning.    It's a holiday."}
回复 支持 7 反对 2
发表于 2022-6-27 13:57:04 来自手机 | 显示全部楼层
1547953 发表于 2022-06-18 23:34:29 Also make sure you open your door and dump out whatever trash you may have on the ground before you leave the truck stop in the morning.    It's a holiday.
","text":"or wash your feet in the sink","replyToPid":463965}
 楼主| 发表于 2022-6-19 07:42:23 来自手机
{"replyTo":"","text":"Wear your flip-flops with pride, and let your sweatpants ride low. When you’re walking across the lot if another driver dares to wish you a good morning, stare back at him and say nothing, better yet don’t look at him at all. Privileged cracker.","replyToPid":0}
支持 1 反对 2
发表于 2022-6-19 07:31:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I am very excite.","replyToPid":0}
发表于 2022-6-20 23:24:42 来自手机
{"replyToPid":0,"replyTo":"","text":"what's that? another colored folks day? I mean they should they don't have enough...."}
支持 2 反对 0
发表于 2022-6-27 13:56:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"in other words another typical day: must be juneteenth every day for you lmao","replyToPid":0}
发表于 2022-6-20 23:49:22 来自手机
{"replyTo":"","text":"So special have to close banks next day, aholes","replyToPid":0}
支持 1 反对 0
发表于 2022-6-22 10:51:38 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"off course leave your fancy HID high beams on the whole night because the truck stop lighting is bright enough"}
发表于 2022-6-23 07:30:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're one of problems not one of the situations.","replyToPid":0}
GMT+8, 2026-2-6 13:16 , Processed in 0.062822 second(s), 24 queries .
