查看: 435|回复: 21
Truck maintenance for owner operators
 楼主| 发表于 2022-6-2 10:30:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"I drive my truck about 500 miles a day and drop and hook to 4 chassis/container combinations a day.  5 days a week. \n\nWhat, when and how often should I be doing for maintaining truck?  \n\nI’ve only actually been driving it for a solid week now so don’t freak out thinking I’ve hurt it already. \n\nPlease and thank you. ","videos":"[]","link":"{}","pics":"[]","canComment":false,"externalShare":false}
发表于 2022-6-2 14:23:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"you should constantly be doing maintenance. \n\n30k mile oil change with shell rotella t6, 15w-40. every oil change, change your air intake filter, fuel filter, and fuel water seperator filter. every 6 months change your DEF line filter. every year change your air compressor filter. every oil change lube your chassis with grease, red n tacky. every 500k miles change your DEF particulate filter. every 6 months clean out your ATF fuel injector and pressure sensors.","replyToPid":0}
回复 支持 1 反对 13
发表于 2022-6-2 22:00:06 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"daily pretrip,post trip, keep your eyes on coupling rubber seals,grease on 5th.other than that regular weekly....monthly maintenance"}
回复 支持 5 反对 1
发表于 2022-6-2 20:03:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good morning! I will give you what worked for me. I bought exact same truck you have now brand new. I put 1.5 million on truck. Never did overhaul.  Maintenance is Key. I grease my truck weekly.  I use Lucas grease. Available at most truckstop.  I use synthetic delvac oil. Also keep check on Antifreeze. Another suggestion check tire pressure. Thats life of your tires. \n\nYou can make a good living doing this job. If you are dedicated!!  Realize your job goes home with you. Unlike being a company driver.  I got faith you can handle this. It's not that hard.  I have owned a truck 25 yrs now. So I know challenges that's involved.","replyToPid":0}
发表于 2022-6-3 07:11:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Every 15k oil , fuel filter, fuel water separator, and grease.  Buy your oil at Walmart.","replyToPid":0}
发表于 2022-6-3 07:28:53 来自手机 | 显示全部楼层
1531200 发表于 2022-06-02 06:23:07 you should constantly be doing maintenance. \n\n30k mile oil change with shell rotella t6, 15w-40. every oil change, change your air intake filter, fuel filter, and fuel water seperator filter. every 6 months change your DEF line filter. every year change your air compressor filter. every oil change lube your chassis with grease, red n tacky. every 500k miles change your DEF particulate filter. every 6 months clean out your ATF fuel injector and pressure sensors.
","text":"They teach you that at Jiffy Lube?","replyToPid":463479}
发表于 2022-6-2 23:45:25 来自手机
1313025 发表于 2022-06-02 10:34:48 Accusme everyone knows what you use red and tacky grease for🤣🤣🤣🤣
","text":"red and tacky, aka your butthole.","replyToPid":463482}
支持 0 反对 3
发表于 2022-6-3 22:56:44 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"30k on newer trucks.  she drives an old dinosaur not a plastic piece of Def,dpf,scr,peiceoftrash.\nyou probably drive for swift.\nthis was for indiangenocider"}
发表于 2022-6-2 18:34:48 来自手机
","text":"Accusme everyone knows what you use red and tacky grease for🤣🤣🤣🤣","replyToPid":463479}
支持 2 反对 0
发表于 2022-6-2 18:57:10 来自手机 | 显示全部楼层
","text":"Thank you for Great time 😊","replyToPid":463479}
发表于 2022-6-2 18:30:46 来自手机
you should constantly be doing maintenance. 30k mile oil change with shell rotella t6, 15w-40. every oil change, change your air intake filter, fuel filter, and fuel water seperator filter. every 6 months change your DEF line filter. every year change your air compressor filter. every oil change lube your chassis with grease, red n tacky. every 500k miles change your DEF particulate filter. every 6 months clean out your ATF fuel injector and pressure sensors.
{"replyToPid":463479,"replyTo":"
","text":"Hey cuz!👹  When did you buy a truck? You drive for swift"}
支持 2 反对 0
发表于 2022-6-2 11:15:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Change my oil and grease it every 15k  the better you maintain it and keep up  on things the better luck you will have out on the road which puts more money in your pocket "}
发表于 2022-6-3 03:17:38 来自手机 | 显示全部楼层
","text":"Accusme nobody cares what you think.","replyToPid":463479}
发表于 2022-6-3 06:04:29 来自手机 | 显示全部楼层
","text":"You don't even know intervals to change oil 🤷‍♂️.  Next time your in Swift shop ask tech for truth","replyToPid":463479}
GMT+8, 2026-4-17 08:14 , Processed in 0.178819 second(s), 24 queries .
