查看: 293|回复: 20
AC issues 2007 Columbia
 楼主| 发表于 2022-5-27 12:20:40 来自手机 | 显示全部楼层 |阅读模式
{"text":"The AC in the front part of my cab quit working but in the bunker it continues to work. Any idea what might be causing this or what I should be looking for? TIA","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-5-27 12:40:33 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Hey bro! Check evap filter first and clean evaporator the cab one. Then check front expansion valve.  or blend door stuck open or heater valve needed to shut coolant off to front heater core. should be issue in front since bunk works good, so it's not compressor or freon or lines."}
回复 支持 2 反对 8
1万
发表于 2022-5-27 18:20:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"does the blower fan work and it's just blowing warm air ?","replyToPid":0}
发表于 2022-5-27 19:19:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Acuseme giving mechanical advice but he couldn't even get a job at Jiffy Lube_.","replyToPid":463302}
发表于 2022-5-27 19:50:04 来自手机 | 显示全部楼层
1529073 发表于 2022-05-27 04:40:33 Hey bro! Check evap filter first and clean evaporator the cab one. Then check front expansion valve.  or blend door stuck open or heater valve needed to shut coolant off to front heater core. should be issue in front since bunk works good, so it's not compressor or freon or lines.
","text":"Advice from a Swift driver 🤣🤣🤣🤣","replyToPid":463293}
 楼主| 发表于 2022-5-27 23:46:23 来自手机 | 显示全部楼层
1031233 发表于 2022-05-27 10:20:49 does the blower fan work and it's just blowing warm air ?
","text":"Blower works just blowing hot air ","replyToPid":463299}
发表于 2022-5-27 15:22:06 来自手机 | 显示全部楼层
","text":"You know me!!","replyToPid":463293}
发表于 2022-5-27 15:17:47 来自手机 | 显示全部楼层
","text":"Hey 👋👋👋👋","replyToPid":463293}
发表于 2022-5-28 01:13:32 来自手机 | 显示全部楼层
910333 发表于 2022-05-27 15:46:23 Blower works just blowing hot air
","text":"Blend door stuck on hot?","replyToPid":463319}
发表于 2022-5-27 18:33:39 来自手机 | 显示全部楼层
","text":"Thanks for great time ☺️☺️","replyToPid":463293}
 楼主| 发表于 2022-5-27 23:46:02 来自手机 | 显示全部楼层
","text":"Thank this is a start I appreciate ya ","replyToPid":463293}
发表于 2022-5-27 18:35:48 来自手机 | 显示全部楼层
","text":"Accusme new account","replyToPid":463293}
发表于 2022-5-27 20:58:11 来自手机 | 显示全部楼层
1488175 发表于 2022-05-27 10:33:39 Thanks for great time ☺️☺️
","text":"Do I know you?","replyToPid":463301}
GMT+8, 2026-2-6 16:20 , Processed in 0.069034 second(s), 24 queries .
