查看: 336|回复: 10
IS THIS SUPPOSE TO BE LIKE THIS?
 楼主| 发表于 2022-5-26 00:11:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"Using my friends truck for two weeks, doing PTI and saw this cable hanging.. it wasn’t hanging before. ","videos":"[]","link":"{}","pics":"[{\"description\":\"HOW DO I FIX IT? \",\"height\":828.0,\"name\":\"\",\"url\":\"\",\"width\":621.0}]","canComment":true,"externalShare":false}
发表于 2022-5-27 12:42:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Htf do you have a c.d.l.?","replyToPid":0}
回复 支持 1 反对 9
发表于 2022-5-26 14:24:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cable from air tank, pull cable drain air or moisture from tank, ziptie to something sturdy, or leave it the way it’s at your call ","replyToPid":0}
回复 支持 6 反对 0
发表于 2022-5-27 01:26:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Or let it ride hit something rip ya tank out lol","replyToPid":0}
发表于 2022-5-27 14:18:24 来自手机 | 显示全部楼层
1529073 发表于 2022-05-27 04:42:54 Htf do you have a c.d.l.?
","text":"CDL Comes with every purchase of flip-flops on Amazon,but only if you have prime.","replyToPid":463295}
发表于 2022-5-27 19:50:38 来自手机
","text":"Do you have green card?","replyToPid":463295}
支持 1 反对 0
发表于 2022-5-27 20:57:04 来自手机 | 显示全部楼层
{"replyToPid":463305,"replyTo":"
1100657 发表于 2022-05-27 11:50:38 This comment has been deleted
","text":"Don't need one I'm an American"}
发表于 2022-5-27 07:21:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤔 Here’s your sign","replyToPid":0}
发表于 2022-7-9 06:31:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"tie it up its just your air release to empty your tank witch you should probably do at the least once a week to get any water condensation out of there","replyToPid":0}
发表于 2022-5-27 20:57:13 来自手机 | 显示全部楼层
1404204 发表于 2022-05-27 06:18:24 CDL Comes with every purchase of flip-flops on Amazon,but only if you have prime.
","text":"hahaha","replyToPid":463296}
发表于 2022-6-4 09:55:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pull it see what happens ","replyToPid":0}
发表于 2022-6-5 01:21:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"air tank drain for moisture build up.","replyToPid":0}
GMT+8, 2026-2-6 13:15 , Processed in 0.064552 second(s), 24 queries .
