查看: 199|回复: 4
CAN ENYONE TELL ME WHY IS SMOKING? First time ever smoke coming out while doing regen
 楼主| 发表于 2022-5-17 08:53:24 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/2022-05-17/JEvoKCshkTRVRVPI.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":1202.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true,"externalShare":false}
发表于 2022-5-17 13:32:41 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Either e.g.r. cooler dumping coolant or d.e.f. injector dumping too much d.e.f. because of bad injector or nox sensor or cracked s.c.r. (just guessing most likely d.e.f. smoke)"}
回复 支持 5 反对 1
发表于 2022-5-19 08:47:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get down there and smell it. Take a big whiff and tell me what it smells and tastes like. Then I can tell you what’s wrong. I need more information for my professional opinion ","replyToPid":0}
发表于 2022-5-20 20:40:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s steam not smoke, most likely fine. Temperature and humidity outside makes a difference if you see the steam or not. Max DEF is used during a Regen ","replyToPid":0}
发表于 2022-6-9 15:33:57 来自手机 | 显示全部楼层
1037330 发表于 2022-05-19 00:47:24 Get down there and smell it. Take a big whiff and tell me what it smells and tastes like. Then I can tell you what’s wrong. I need more information for my professional opinion
","text":"You trynna kill the man 😅","replyToPid":462991}
GMT+8, 2026-2-6 16:20 , Processed in 0.056209 second(s), 24 queries .
