查看: 206|回复: 3
How does the law work? Can you have tandems shorter?
 楼主| 发表于 2022-5-3 23:24:54 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-5-3 23:51:14 来自手机 | 显示全部楼层
1031233 发表于 2022-05-03 15:37:59 depends what you are trying to accomplish. if you need more weight on the trailer axles then you need to slide them forward, I would put them where the weight was equally distributed. if you're looking for the coolest look then slide them all the way back...
","text":"😂 ","replyToPid":462340}
1万
发表于 2022-5-3 23:37:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends what you are trying to accomplish. if you need more weight on the trailer axles then you need to slide them forward, I would put them where the weight was equally distributed. if you're looking for the coolest look then slide them all the way back...","replyToPid":0}
发表于 2022-5-7 04:00:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, that is max length or you'll have a length violation. In FL. it is 100.00.","replyToPid":0}
GMT+8, 2026-4-15 17:37 , Processed in 0.110632 second(s), 24 queries .
