查看: 174|回复: 3
Update
 楼主| 发表于 2022-4-29 09:19:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone updated there cluster or know anyone that has? I'm trying to figure out how to keep the center information lights but replace the old gauges with new. $180 for one air gauge is a rip off when a new led or analog is well under $100.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":736.0,\"name\":\"\",\"url\":\"\",\"width\":1079.0}]","canComment":true,"externalShare":false}
禁止发言
发表于 2022-4-30 04:21:30 来自手机 | 显示全部楼层
 楼主| 发表于 2022-4-30 02:26:49 来自手机 | 显示全部楼层
147103 发表于 2022-04-29 11:05:25 You do realize your gauges get their  signal from same sensor as your ECM.  in order to switch to different gauges. You would need to put in a T in locations where sensors are located.  So the original sensor and sensor for new gauges work together.  It can be done. Not a complicated job.
","text":"Thanks for the info. Guess it will happen down the road and no time soon.","replyToPid":462157}
禁止发言
发表于 2022-4-29 19:05:25 来自手机 | 显示全部楼层
GMT+8, 2026-4-18 20:46 , Processed in 0.084178 second(s), 24 queries .
