查看: 264|回复: 5
Does air conditioning continual effect the engine of a tractor? (International).
 楼主| 发表于 2022-4-27 00:20:15 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-4-28 11:59:15 来自手机 | 显示全部楼层
678033 发表于 2022-04-28 02:01:23 It effects fuel efficiency but not as much as the heater. That seems funny because my APU runs more on the AC. Did you know, in cold places a car heater can reduce electric car battery efficiency by 41%? I don’t know how they think they can ditch diesel in Fargo. Good luck to that piece of legislation.
","text":"it's winter fuel responsible for the inefficiency.  heater uses no power from the motor.","replyToPid":462107}
回复 支持 1 反对 4
发表于 2022-4-27 07:16:44 来自手机
{"replyTo":"","text":"There’s so many things wrong with this question (if it is a question) it’s not worth answering.","replyToPid":0}
支持 3 反对 0
275
发表于 2022-4-28 10:01:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"It effects fuel efficiency but not as much as the heater. That seems funny because my APU runs more on the AC. Did you know, in cold places a car heater can reduce electric car battery efficiency by 41%? I don’t know how they think they can ditch diesel in Fargo. Good luck to that piece of legislation. ","replyToPid":0}
发表于 2022-4-29 05:13:07 来自手机
1496633 发表于 2022-04-28 03:59:15 it's winter fuel responsible for the inefficiency.  heater uses no power from the motor.
","text":"Did swift teach you that? we all know your a company driver","replyToPid":462110}
支持 1 反对 0
发表于 2022-4-27 20:44:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Horsepower?? International????😂😂😂😂😂😂😂😂😂😂","replyToPid":0}
发表于 2022-4-27 02:49:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes it takes horsepower away from engine","replyToPid":0}
发表于 2022-4-27 02:29:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"It shouldn’t, unless your.  A/C Compressor locks up and tears your belt.. ","replyToPid":0}
GMT+8, 2026-4-15 17:25 , Processed in 1.546191 second(s), 25 queries .
