查看: 386|回复: 10
I need help with trailer
 楼主| 发表于 2022-4-25 03:30:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi guys.\nI took a trailer from yard and trying to slide the tandem but the wheels are spinning. It’s second time in this year 🤬. \nI saw on the YouTube: remove blue air hose and connect red one to blue glad hand, that will apply air to trailer brakes. Release trailer and tractor brakes and than slide the tandem.\nI did it but still not working, the wheels are spinning.\nI can slide the tandem to rear by backing to curb but I don’t know how to push to front.\nAny ideas??? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-4-25 04:33:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drive forward 10pmh, pull hand brake. On a side note, the wheels are spinning b cause the brakes are out of adjustment.","replyToPid":0}
发表于 2022-4-25 04:33:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also make sure all 4 pins are in. ","replyToPid":0}
发表于 2022-5-2 10:12:25 来自手机 | 显示全部楼层
936953 发表于 2022-04-27 14:09:58 Old wives tail, there’s 2 types of adjustments.\nOnes that adjust when you press the brakes and ones that adjust when you release. Think about it, how would the slack adjuster know you’re  backing up?? 😂
","text":"One day ur learn how the self adjuster’s works on adjusting ur brakes ","replyToPid":462067}
发表于 2022-4-26 01:06:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Self adjusting brakes is to b adjusted by backing up and tapping ur breaks. Just like on old model cars and trucks ","replyToPid":0}
发表于 2022-4-27 22:09:58 来自手机 | 显示全部楼层
{"replyToPid":461998,"replyTo":"
758212 发表于 2022-04-25 17:06:23 Self adjusting brakes is to b adjusted by backing up and tapping ur breaks. Just like on old model cars and trucks
","text":"Old wives tail, there’s 2 types of adjustments.\nOnes that adjust when you press the brakes and ones that adjust when you release. Think about it, how would the slack adjuster know you’re  backing up?? 😂"}
发表于 2022-4-26 17:03:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you want the weight (trailer) to go forward or backward?","replyToPid":0}
 楼主| 发表于 2022-4-26 00:26:11 来自手机 | 显示全部楼层
1223218 发表于 2022-04-25 11:39:12 If your wheels are spinning while your trying to move your tandems it means the slack adjusters need to be adjusted.. if your trailer has self adjusters maybe they need to be replaced. You can put a 4x4 block of wood or something else on one of the tires to keep your wheels from spinning then rock your truck back and forth till your pins get released then try move your tandems….    If your sliding pins don’t go in hit them with a hammer till they do in..  hope it helps
","text":"Thank. Pins are OK. Brakes are not adjusted ","replyToPid":461991}
 楼主| 发表于 2022-4-25 05:11:06 来自手机 | 显示全部楼层
936953 发表于 2022-04-24 20:33:00 Drive forward 10pmh, pull hand brake. On a side note, the wheels are spinning b cause the brakes are out of adjustment.
","text":"I will try soon","replyToPid":461986}
 楼主| 发表于 2022-4-25 05:11:35 来自手机 | 显示全部楼层
{"replyToPid":461987,"replyTo":"
936953 发表于 2022-04-24 20:33:34 Also make sure all 4 pins are in.
","text":"😃"}
发表于 2022-4-25 19:39:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If your wheels are spinning while your trying to move your tandems it means the slack adjusters need to be adjusted.. if your trailer has self adjusters maybe they need to be replaced. You can put a 4x4 block of wood or something else on one of the tires to keep your wheels from spinning then rock your truck back and forth till your pins get released then try move your tandems….    If your sliding pins don’t go in hit them with a hammer till they do in..  hope it helps"}
GMT+8, 2026-4-17 18:38 , Processed in 0.088128 second(s), 24 queries .
