查看: 269|回复: 4
Northeast loads
 楼主| 发表于 2022-4-22 06:05:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do companies pay a different rate for northeast loads? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-4-27 15:49:53 来自手机
{"replyToPid":462006,"replyTo":"
65688 发表于 2022-04-26 06:46:24 This comment has been deleted
","text":"in trucking, probably not. Store managers, yes."}
支持 0 反对 2
发表于 2022-4-26 09:14:02 来自手机
{"replyToPid":461972,"replyTo":"
1457992 发表于 2022-04-23 14:46:35 This comment has been deleted
","text":"Math, science, and history taught in k-12 can teach you that. Not even algebra is needed."}
支持 0 反对 2
发表于 2022-4-22 23:29:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rates are based on load volume to truck ratio. They make no sense if you try to understand it any other way. Sometimes it's better to deadhead on route 500 miles and pick up a similar paying load with the same destination.\n\nThere is definitely a market for a better match making system for freight, a mix of uber freight, ebay, and jb hunt.","replyToPid":0}
发表于 2022-4-26 14:46:24 来自手机
{"replyToPid":462003,"replyTo":"
1489087 发表于 2022-04-26 01:14:02 This comment has been deleted
","text":"Is algebra EVER needed?"}
支持 1 反对 0
发表于 2022-4-23 22:46:35 来自手机
1489087 发表于 2022-04-22 15:29:59 Rates are based on load volume to truck ratio. They make no sense if you try to understand it any other way. Sometimes it's better to deadhead on route 500 miles and pick up a similar paying load with the same destination.\n\nThere is definitely a market for a better match making system for freight, a mix of uber freight, ebay, and jb hunt.
","text":"Swift teach you that?🤣","replyToPid":461963}
支持 1 反对 0
发表于 2022-4-22 06:22:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes. It’s usually a higher pay rate","replyToPid":0}
发表于 2022-4-22 09:17:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends whether it's going in or going out....🤔","replyToPid":0}
发表于 2022-4-23 15:01:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"At the time of this post..\nMy experience servicing the 48..\nRates in the current  market with tremendous uncertainty. I've found location/company brokering freight may not play a factor. Mostly the type of freight, urgency, and destination from pickup/delivery plays a huge factor with  rates,  Contracting directly with shipper, if possible yeilds better rates than load boards/brokerages. A sure income beating inflation/maintenance is either customer direct/lane-haul or run specific freight type.","replyToPid":0}
GMT+8, 2026-2-4 08:00 , Processed in 0.105581 second(s), 24 queries .
