查看: 449|回复: 12
Trailer lights not working
 楼主| 发表于 2022-4-15 08:03:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Yesterday my trailer lights went out so I checked the cable that connects the trailer to the truck. The cable seem to be working fine no debris‘s or grease on it so I want to check the fuse box. I replaced two fuses that seem to be out now my trailer does not idle so after a few minutes it’ll turn off when I want to turn it back on and check on the lights the lights came back on so I thought those fuses were the problem. This morning when I took off I noticed that my trailer lights were off again, so I pulled over to check on them and I thought maybe they turn off whenever I took off so I turned off the truck again and turned it back on and the lights came back on so now whenever I takeoff my trailer lights turn off. My blinkers and emergency signals turned on though so do my brake lights does anyone have any idea what it could be?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-4-15 11:19:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Seems nobody here speaks proper English or knows what a complete sentences is. I'm also assuming when you say your trailer \"doesn't idle,\" you mean to say the tail lights don't stay on. If they work, but the lights go on and off, check for a loose connection. The other 4th grade English speakers were trying to tell you to bend.the connector pins so that when you plug them in they make firm contact. I concur with that assessment but the delivery could use proper English for clarity.","replyToPid":0}
回复 支持 0 反对 6
发表于 2022-4-16 03:03:30 来自手机
1050153 发表于 2022-04-15 15:37:13 Biden is president and has been 2 yrs
","text":"yeh, you keep trying to forget how your president tried to steal the elections and start a civil war. I will never forget.","replyToPid":461746}
支持 0 反对 5
发表于 2022-4-15 08:25:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"If trailer has connector split ends take screwdriver 🪛 spread ends","replyToPid":0}
 楼主| 发表于 2022-4-15 09:12:17 来自手机 | 显示全部楼层
908202 发表于 2022-04-15 00:49:29 Driver if you cant comprehend what old marine is tellin you just in the daylight you dont need trailer lights then🤣
","text":"You’re right mr supertrucker ","replyToPid":461702}
发表于 2022-4-15 08:49:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Driver if you cant comprehend what old marine is tellin you just in the daylight you dont need trailer lights then🤣","replyToPid":0}
发表于 2022-4-15 23:19:17 来自手机
{"replyTo":"","text":"fake news. But as more election stealing tumpards are being focused on, the truth is coming out. Maybe tump will go to jail, if America can deliver justice. the only reason tump failed to steal the election, is because of all the spineless cowards that post here and not present on Jan 6th.","replyToPid":461738}
支持 0 反对 3
发表于 2022-4-15 23:17:30 来自手机
147103 发表于 2022-04-15 15:00:25 I NO where said I was hero. YOU pretend to be me and follow my posts. So it's easy to see you worship me. I tell you what. my little  dogs always sit by my feet. I will tell them you want that spot.  I can reach down and pat you on the head every once in awhile
","text":"You would be a modern day sIave owner, can't own them blacks, own them other species. No one would sit next to you if they had the freedom not to.","replyToPid":461739}
支持 1 反对 2
发表于 2022-4-15 22:36:17 来自手机
{"replyToPid":461736,"replyTo":"
147103 发表于 2022-04-15 12:12:50 Kid you suffering from HERO worship??
","text":"🤣. You think you're a hero? or do you think every marine is a hero? or every service member? or no brain zombies are heros who do what they're told are heroes? Self entitled brat expects a discount everywhere  you go and wants everyone to know about his service. Your whole identity is your service. 🥲\n\nit's people like you, who don't have their own minds and opinions and can't formulate their own thoughts is why the world is a bad place.\n\nYou're no different from the russian soldiers.  Had you been in a real war, with a country that wasn't developing, you would be committing the same war crimes ever war sees."}
支持 0 反对 3
82
发表于 2022-4-15 09:20:48 来自手机 | 显示全部楼层
1235360 发表于 2022-04-15 01:12:17 You’re right mr supertrucker
","text":"You are correct sir i am a super trucker but on the real u got a ground problem spread them out on trailer and truck side too ","replyToPid":461706}
禁止发言
发表于 2022-4-15 08:09:55 来自手机 | 显示全部楼层
发表于 2022-4-15 08:47:13 来自手机 | 显示全部楼层
147103 发表于 2022-04-15 00:09:55 Yep I do. Check 2 things. Your ground pin in your plug on trailer. Also check pin for Your trailer lights. Do you understand what I mean? That's normally all that's wrong
","text":"☝️☝️☝️☝️☝️☝️☝️☝️☝️☝️☝️💯💯💯💯💯💯💯💯💯💯💯","replyToPid":461696}
 楼主| 发表于 2022-4-15 09:10:39 来自手机 | 显示全部楼层
1158806 发表于 2022-04-15 00:25:45 If trailer has connector split ends take screwdriver 🪛 spread ends
","text":"Got it, thanks bro ","replyToPid":461697}
发表于 2022-4-15 10:37:50 来自手机 | 显示全部楼层
908202 发表于 2022-04-15 01:20:48 You are correct sir i am a super trucker but on the real u got a ground problem spread them out on trailer and truck side too
","text":"a couple of new power cord ends won't hurt either","replyToPid":461707}
GMT+8, 2026-2-6 21:21 , Processed in 0.064490 second(s), 24 queries .
