查看: 217|回复: 8
97 International fuse locations
 楼主| 发表于 2022-4-14 21:07:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"I need some help, with my truck that is. I have a 97 International 9400 Eagle that the fuse location diagram in the glove box is gone. I've checked others around me but either the trucks newer or its missing as well. So far no dealer around me even has one.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2022-4-15 08:27:30 来自手机 | 显示全部楼层
禁止发言
发表于 2022-4-14 21:36:03 来自手机 | 显示全部楼层
发表于 2022-4-15 09:35:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just a little off subject driver why are u naked on a rocking horse shooting a pistol???? Maybe you shouldn’t be using a test light it’s pointed on the end u may poke yourself ","replyToPid":0}
 楼主| 发表于 2022-4-15 11:36:36 来自手机 | 显示全部楼层
147103 发表于 2022-04-15 00:27:30 Yes im familiar.  Still use test light on both side of reset.  Because they do go bad. International trucks I worked on have a simple electrical system.  Also whatever isn't working.  Check that switch also. For power in and out
","text":"And that's why I ask. Sometimes the simplest things are overlooked. I will do some probing tomorrow and get back. Appreciate it.","replyToPid":461698}
 楼主| 发表于 2022-4-15 08:04:12 来自手机 | 显示全部楼层
147103 发表于 2022-04-14 13:36:03 That's easy to figure out. Fuse box is behind panel where glove box normally is. Get yourself a test light and check fuses. no diagram  needed
","text":"They have the reset fuses.","replyToPid":461677}
发表于 2022-4-15 09:36:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"U may have a fuse blown yourself driva 😂💯","replyToPid":0}
 楼主| 发表于 2022-4-15 11:35:01 来自手机 | 显示全部楼层
908202 发表于 2022-04-15 01:35:16 Just a little off subject driver why are u naked on a rocking horse shooting a pistol???? Maybe you shouldn’t be using a test light it’s pointed on the end u may poke yourself
","text":"That's my doppelganger. I haven't found a rocking horse yet. Have the rest, but switched to vodka.","replyToPid":461708}
发表于 2022-4-17 10:55:32 来自手机 | 显示全部楼层
","text":"Got no ac in the truck that why is naked lol 😂 ","replyToPid":461708}
GMT+8, 2026-4-18 22:22 , Processed in 0.085560 second(s), 24 queries .
