查看: 176|回复: 2
I wonder how often yall drivers actually grease your fifth wheel n when u do it do yall hook your trailer back up
 楼主| 发表于 2022-4-14 08:56:27 来自手机 | 显示全部楼层 |阅读模式
{"text":"Properly by raising the trailer n dumping your bags so the grease dont slide off the front of fifth wheel when u hook and do yall know the benefits of doing it correctly ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-4-14 09:04:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do not need to do that. I do not have the fifth wheel. I only have the eighteen wheel.","replyToPid":0}
回复 支持 8 反对 0
发表于 2022-4-14 09:22:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Run jost fifthweel with grease hose going to king pin , accessible from the side , \nAnd $11.00 plastic plates \nWorks fairly well ,  ","replyToPid":0}
GMT+8, 2026-2-6 19:45 , Processed in 0.059134 second(s), 24 queries .
