查看: 688|回复: 18
governed speed
 楼主| 发表于 2022-4-4 22:03:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone know of someone who can change the governed speed and idle timer on a 2019 Freightliner  evolution? It can be offf the books too so anyone even backyard mechanics or shops not booked out 3 weeks.in the Riverside, CA area would begreat.  Yes, I just bought it.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-4-5 00:23:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not sure if id turn it up to much plastic be flying off that junk 😂💯","replyToPid":0}
回复 支持 7 反对 0
发表于 2022-4-4 23:45:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"If u own it take it to freightliner n have em hook it up ","replyToPid":0}
回复 支持 6 反对 0
发表于 2022-4-5 01:53:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"make sure you have your four digit pin number before bringing it in to get turned up. if you just bought it. have you seen the price of fuel yet? why would you turn it up more? turn it down! 62mph haha you're welcome","replyToPid":0}
发表于 2022-4-5 00:51:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"What if your mask will fly off if you turn it up 🤔😂","replyToPid":0}
发表于 2022-4-6 20:56:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Yes I do but, they are not in your area AND tbh I do not feel comfortable disclosing that information in this forum. I would suggest taking it back to wherever you bought it from to have it taken off or take it to the dealership. If it’s not yours then TECHNICALLY you may not be able to do that without the owner’s permission. Good luck and be safe. "}
发表于 2022-4-4 22:38:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unless it’s a company truck, I don’t see why it’d have to be off the books. ","replyToPid":0}
发表于 2022-4-5 08:26:28 来自手机 | 显示全部楼层
147103 发表于 2022-04-04 21:46:31 I have DD 16 that's turned to max. it's strong and good on fuel. if I don't push it. However I also have owned numerous mechanical Cat and Cummins.  I think on the pull. The mechanical wins. Mechanical is definitely more reliable.
","text":"Id take a big cam 400 with a zero button n couple shims any day ","replyToPid":461256}
发表于 2022-4-5 05:07:13 来自手机 | 显示全部楼层
1388152 发表于 2022-04-04 20:53:36 I can make a dd15 spank anything with so simple programming those old old Pete's are junk compared to the new freightshakers
","text":"Roflmmfao u got jokes driva ","replyToPid":461249}
1万
发表于 2022-4-4 22:49:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"you would have to call some shops to see if they can change the settings... where I work they have to take the truck to the dealer to change those settings...","replyToPid":0}
发表于 2022-4-5 04:12:54 来自手机 | 显示全部楼层
922959 发表于 2022-04-04 14:38:40 Unless it’s a company truck, I don’t see why it’d have to be off the books.
","text":"She means payin cash so no taxes","replyToPid":461233}
发表于 2022-4-5 04:53:36 来自手机 | 显示全部楼层
908202 发表于 2022-04-04 16:23:57 Not sure if id turn it up to much plastic be flying off that junk 😂💯
","text":"I can make a dd15 spank anything with so simple programming those old old Pete's are junk compared to the new freightshakers","replyToPid":461236}
发表于 2022-4-5 04:54:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can change parameters","replyToPid":0}
GMT+8, 2026-4-15 12:04 , Processed in 0.201007 second(s), 24 queries .
