查看: 222|回复: 2
CR ENGLAND 2021 INTERNATIONAL
 楼主| 发表于 2022-3-27 09:27:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’ve been trying to get this truck to idle but none of the in cab mechanics work. Can someone show pic a pic/video of where it is? I’m gonna put a heat pack on it but I need someone to show a wide view of where it is.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-3-27 11:32:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Contact CR England mechanic shop. They should have given you the number in training.","replyToPid":0}
发表于 2022-3-28 21:37:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"A lot of company trucks are set to shut off after so many minutes based on outside temperature. I own my own truck and turned that feature off. If it’s a company truck they might not turn it off for you. Some trucks have an idle management option that will turn your truck on when the batteries get low to charge them back up. Usually it’s a switch on the dash, or some are accessed on the screen for your gauges. ","replyToPid":0}
发表于 2022-3-27 10:33:25 来自手机
{"replyTo":"","text":"i seen you out robbing the 7-11","replyToPid":0}
支持 1 反对 0
GMT+8, 2026-4-17 21:55 , Processed in 0.098632 second(s), 24 queries .
