查看: 186|回复: 7
Please tell me. What overweight is possible without penalty? I have a box track 26000
 楼主| 发表于 2022-3-25 11:35:06 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-3-25 13:22:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"axle weights apply to all motor vehicles, 26,000 lbs for single axle, 34,000 lbs for tandems.","replyToPid":0}
回复 支持 1 反对 3
发表于 2022-3-26 06:57:48 来自手机 | 显示全部楼层
1458501 发表于 2022-03-25 05:22:14 axle weights apply to all motor vehicles, 26,000 lbs for single axle, 34,000 lbs for tandems.
","text":"Tell everyone what NO PARKING means???","replyToPid":460908}
发表于 2022-3-25 12:56:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not sure what a box track is but, if you don’t have a CDL  and your 26001 pounds they will put you out of service. If that’s not your question. axle weights and gross weight violations are just 💰 money. They don’t go against your license, but more likely than not they will not let you leave until you are legal weights if you get caught.","replyToPid":0}
1万
发表于 2022-3-25 20:32:42 来自手机 | 显示全部楼层
1031233 发表于 2022-03-25 12:31:00 i thought it was 20,000 for a single rear axle and 34,000 for tandem rear axles. then you still have the front steer axle which would depend on the axle rating and front tire ratings... your front axle could be up to 20,000 with the proper setup. finally it would depend on how much gross weight you have the truck registered for...
","text":"plus all this could be different from state to state depending on the state laws...","replyToPid":460917}
1万
发表于 2022-3-25 20:31:00 来自手机 | 显示全部楼层
","text":"i thought it was 20,000 for a single rear axle and 34,000 for tandem rear axles. then you still have the front steer axle which would depend on the axle rating and front tire ratings... your front axle could be up to 20,000 with the proper setup. finally it would depend on how much gross weight you have the truck registered for...","replyToPid":460908}
发表于 2022-3-26 04:41:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"26001is overweight, you don't have an option to be overweight and it's legal, that's why it's called overweight.. Stay under 26000 and you will be fine, If you want to haul more you need a day cab at minimum","replyToPid":0}
发表于 2022-3-26 14:04:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"200 lbs over should be ok ","replyToPid":0}
GMT+8, 2026-2-7 03:25 , Processed in 0.105239 second(s), 24 queries .
