查看: 267|回复: 9
A guy at the gas station asked the cashier for $5 on pump 3. Where is he going? Pump 4??
 楼主| 发表于 2022-3-17 21:23:26 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-3-17 22:00:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"a lot of \"mind your own business\" needed here.","replyToPid":0}
回复 支持 2 反对 14
发表于 2022-3-17 23:16:58 来自手机 | 显示全部楼层
1452669 发表于 2022-03-17 14:00:44 a lot of \"mind your own business\" needed here.
","text":"Let's see..... you on here reading others posts. Then you tell others to mind their business.  Isn't that like the pot calling the kettle black","replyToPid":460620}
回复 支持 12 反对 1
发表于 2022-3-17 22:16:45 来自手机 | 显示全部楼层
","text":"You may need to take your own advice ","replyToPid":460620}
回复 支持 12 反对 0
发表于 2022-3-17 22:36:28 来自手机 | 显示全部楼层
","text":"How about you crawl back in your hole.  we don't need your opinion","replyToPid":460620}
回复 支持 10 反对 0
发表于 2022-3-18 01:28:27 来自手机 | 显示全部楼层
","text":"Maybe you should practice what you preach","replyToPid":460620}
回复 支持 7 反对 0
发表于 2022-3-18 02:44:50 来自手机 | 显示全部楼层
","text":"Typical from you","replyToPid":460620}
回复 支持 6 反对 0
禁止发言
发表于 2022-3-17 21:51:52 来自手机 | 显示全部楼层
回复 支持 6 反对 0
发表于 2022-3-18 03:35:56 来自手机 | 显示全部楼层
","text":"Mind your own business Accusme","replyToPid":460620}
发表于 2022-3-18 06:05:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Could be for reefer unit \n\nOr maybe just maybe if it’s an old timer he’s testing to see if receipt is time stamped for obvious reasons \n","replyToPid":0}
GMT+8, 2026-2-6 21:20 , Processed in 0.076860 second(s), 24 queries .
