查看: 270|回复: 6
Dot medical card
 楼主| 发表于 2022-3-17 15:37:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"I stopped driving over the road for personal reasons and I am now ready to go back over the road. I thought I had more time until I had to renew my medical card but I just realized it expired about 4 months ago. I have a Texas CDL. Can I just do my physical tomorrow and be ok? Does anyone know what happens in my situation? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-3-17 22:09:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"short answer,  yes. You do your physical and submit your report to the DMV via online or in-person.","replyToPid":0}
回复 支持 2 反对 6
发表于 2022-3-18 01:10:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Once your card expired, your CDL was downgraded to a regular drivers license. Most states give 12 months to submit a valid Medical Card and get your CDL back. After the 12 months you have to retest and start over. Also note, the medical card must be submitted within 14 days of the exam or it will not be accepted.","replyToPid":0}
发表于 2022-3-18 05:05:01 来自手机
1452669 发表于 2022-03-17 14:09:51 short answer,  yes. You do your physical and submit your report to the DMV via online or in-person.
","text":"https://www.mayoclinic.org/diseases-conditions/narcissistic-personality-disorder/symptoms-causes/syc-20366662","replyToPid":460623}
支持 3 反对 0
48
发表于 2022-3-18 00:50:06 来自手机 | 显示全部楼层
","text":"Tell everyone how you can't read NO PARKING.  Then your giving advice?🤣🤣🤣🤣","replyToPid":460623}
 楼主| 发表于 2022-3-17 21:03:25 来自手机 | 显示全部楼层
65688 发表于 2022-03-17 11:28:23 if you have or will be operating under your own authority then, yes, should be able to just do a physical and you're good.  However,  if you are going to drive for someone else or lease on somewhere, then they will probably make you do another physical again anyway.  I would suggest checking with whomever you plan on getting on with (if that is the route you are going) and see what they may require specifically.
","text":"Thank you for answering. I heard a lot of different things from different drivers one of them being that I would lose my cdl and would have to retake the written test and driving test. I would be going with a new company I really hope it works out","replyToPid":460603}
发表于 2022-3-17 19:28:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you have or will be operating under your own authority then, yes, should be able to just do a physical and you're good.  However,  if you are going to drive for someone else or lease on somewhere, then they will probably make you do another physical again anyway.  I would suggest checking with whomever you plan on getting on with (if that is the route you are going) and see what they may require specifically.","replyToPid":0}
发表于 2022-3-29 10:38:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"need a dispatcher im your guy","replyToPid":0}
GMT+8, 2026-4-17 20:19 , Processed in 0.125859 second(s), 24 queries .
