查看: 200|回复: 7
Cb radio
 楼主| 发表于 2022-3-17 13:11:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m new to trucking just got a cab radio and I hooked it but I just never get anything over the radio should I get my radio checked or dose nobody use the radio like that anymore ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-3-17 14:59:55 来自手机 | 显示全部楼层
1441691 发表于 2022-03-17 06:46:05 How much food gets stuck in that beard?
","text":"depends what time of the year it is. not much now. winter is almost over. but usually in the fall I squirrel away enough scraps to try to make it through the winter. in case of a break down on a cold night.","replyToPid":460594}
1万
发表于 2022-3-17 19:39:00 来自手机 | 显示全部楼层
612134 发表于 2022-03-17 06:59:55 depends what time of the year it is. not much now. winter is almost over. but usually in the fall I squirrel away enough scraps to try to make it through the winter. in case of a break down on a cold night.
","text":"that's great 👍","replyToPid":460595}
发表于 2022-3-17 14:46:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"How much food gets stuck in that beard?","replyToPid":460591}
发表于 2022-3-17 14:40:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"No dose. De cab radio","replyToPid":0}
1万
发表于 2022-3-17 19:42:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"murda0925, you never said if you had or hooked up a CB antenna to your radio ???","replyToPid":0}
 楼主| 发表于 2022-3-17 21:48:28 来自手机 | 显示全部楼层
1031233 发表于 2022-03-17 11:42:21 murda0925, you never said if you had or hooked up a CB antenna to your radio ???
","text":"I’m using the antenna that came with truck I’m a new cascadia but I have antenna but there is no where to mount it on to the truck ","replyToPid":460608}
发表于 2022-3-18 11:45:39 来自手机 | 显示全部楼层
1254561 发表于 2022-03-17 13:48:28 I’m using the antenna that came with truck I’m a new cascadia but I have antenna but there is no where to mount it on to the truck
","text":"https://www.amazon.com/PROCOMM-PCA5502-Cascadia-Aluminum-Antenna/dp/B07L3NTHM3/ref=asc_df_B07L3NTHM3/?tag=hyprod-20&linkCode=df0&hvadid=312099670269&hvpos=&hvnetw=g&hvrand=6788502370817356936&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1019973&hvtargid=pla-871489949232&psc=1","replyToPid":460617}
GMT+8, 2026-4-17 09:31 , Processed in 0.103425 second(s), 24 queries .
