查看: 549|回复: 7
where is the slack adjuster?
 楼主| 发表于 2022-3-15 10:57:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"any chance someone can post a photo of the new 2022 freightliner cascadia slack adjuster? There doesn't seem to be one...","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-3-16 04:05:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy a w9","replyToPid":0}
发表于 2022-3-15 11:15:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Disc brakes?","replyToPid":0}
发表于 2022-3-16 06:33:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Guess that’d be a step up from a junky freightliner but class pays get a Peterbilt ten pho","replyToPid":460550}
发表于 2022-3-16 02:39:12 来自手机 | 显示全部楼层
842845 发表于 2022-03-15 03:08:07 Why? That’s all pretrip nonsense! Just look to make sure you don’t see any leaks, clamps tightened, belts secure, brake chamber and brake line secure, u-bolts tight around leaf spring on axle, fluids filled!
","text":"I'm still doing my pretrip. Its been 3 yrs now. Can't find the canooter valve or the headlight fluid resivoir to make sure its full.","replyToPid":460522}
发表于 2022-3-16 03:24:01 来自手机 | 显示全部楼层
764614 发表于 2022-03-15 18:39:12 I'm still doing my pretrip. Its been 3 yrs now. Can't find the canooter valve or the headlight fluid resivoir to make sure its full.
","text":"It’s right next to the blinker fluid  reservoir. Lol","replyToPid":460548}
发表于 2022-3-15 11:08:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why? That’s all pretrip nonsense! Just look to make sure you don’t see any leaks, clamps tightened, belts secure, brake chamber and brake line secure, u-bolts tight around leaf spring on axle, fluids filled! ","replyToPid":0}
发表于 2022-3-15 22:39:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"no slacc adjuster on them","replyToPid":0}
GMT+8, 2026-2-4 07:59 , Processed in 0.121486 second(s), 24 queries .
