查看: 48|回复: 0
GOOD TA IN WAPAKONETA OHIO MECHANICAL. DILLAN 5 STARS
 楼主| 发表于 2022-3-5 06:00:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"one of the best mechanics shop with a knowledgeable guy. I had hub seal leak which the dealer fixed less than a month ago. I bought it here and he showed me the problem  and told me to replace the hub seal bearing and gasket. I was not sure so he just replaced the seal and was putting it back and said he did not like the way it look after he assembled and took it off again and what do you know it was no good. so I finally coughed the money and replaced it. he said wise move because the back seal was wet also. I highly recommend this place. His name is Dillan. \nta of wapakoneta.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
GMT+8, 2026-4-17 02:14 , Processed in 0.076478 second(s), 24 queries .
