查看: 433|回复: 5
x15 leaking coolant
 楼主| 发表于 2022-2-26 06:19:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"I got an x15 that is leaking coolant or pushing it out of this boot on the passenger side. anybody know what the problem is? everything seems to be tight. no loose parts.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2022-2-26 20:58:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"change the hose.  they swell and shrink from heat and cold eventually not sealing anymore.","replyToPid":0}
发表于 2022-2-27 13:25:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Same thing happened to me in WI last month! Temp in single digits! Took to kenworth dealership! They said clamps just needed to be tightened! Happened a few days later at truck stop! Called road breakdown! They just came out and tightened clamps! Said nothing to worry about! Just a cold water leak! Added more coolant! Didn’t happen again! ","replyToPid":0}
发表于 2022-3-3 08:22:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"cold water leaks tighten up all the hose clamps","replyToPid":0}
发表于 2022-2-28 12:38:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tightin them dang clamps man 10 mm ","replyToPid":0}
发表于 2022-2-27 06:54:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"You shoulda bought a Paccar engine ","replyToPid":0}
GMT+8, 2026-4-15 14:02 , Processed in 0.137053 second(s), 25 queries .
