查看: 190|回复: 3
off topic
 楼主| 发表于 2022-2-24 01:21:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"my headlights are properly mounted and secured not chipped cracked or broken. it functions as high and low beam. they are clear in color.  check functionality on the in cab. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2022-2-27 20:00:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"we got new trucks, they forgot to put a clutch pedal in these trucks, shift lever also gone ??? there is this flimsy plastic thing that looks like it came off a child's toy for a shifter...","replyToPid":0}
发表于 2022-2-27 13:00:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Should take about 10 minutes! Jaw is locked around king pin! Air line glad hands and electric line  connected! Landing gear up! Trl Tandem pins in locked position on all four sides! Trl Tandem airlines not touching ground! No missing mud flaps! Trl door rods in locked position top and bottom! Pad lock on trl door! Thumped all tires on tractor, trl to make sure it’s not flat! Tire tread is good! No missing lug nuts! Lights and 4 way flashers working! Stand in front of tractor: no leaks under tractor! Open hood: no audible leaks! Clamps tightened! Coolant, oil, windshield fluid good! Belts good! Suspension: u-bolts tight around leaf spring around axle! Steering: steering fluid, steering shaft, gear box, 3 pc steering linkage, castle nuts, cotter pins good! Brake chamber, brake lines good! Brake pads, brake drum good!  You’re good to go! Time to roll! ","replyToPid":0}
发表于 2022-2-27 22:01:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mr freeze: Ha 😂! You’ll get used to it! Only problem I had was it’s so simple that I felt like I was falling asleep! Took the skill out of it! Where as before my mind seemed more sharp from shifting and kept me more awake! No regrets now though! A habit usually takes about 21 days to break! Get back with me in 21 days! Chances are you’ll end up liking it better! I know I do! 😂! ","replyToPid":0}
GMT+8, 2026-2-4 17:20 , Processed in 0.069374 second(s), 24 queries .
