查看: 360|回复: 11
split breaks
 楼主| 发表于 2022-2-22 20:36:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"doesn't driving off the qc count as a violation of your clock? so if I switch to paper logs I'm correcting the violation but it seems like that's still a violation. the reason I'm wondering is because I was operating split break and my qc crashed so I switched to paper. wouldn't I need to do a ten hour from driving violation? I am anyways. it's easier to track. just curious. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-2-22 21:10:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re a man you’re automatically guilty ","replyToPid":0}
回复 支持 2 反对 3
发表于 2022-2-23 01:09:39 来自手机 | 显示全部楼层
{"replyToPid":459642,"replyTo":"
1432748 发表于 2022-02-22 16:22:29 This comment has been deleted
","text":"Swift pays me same no matter how high fuel goes"}
发表于 2022-2-23 01:08:19 来自手机
","text":"My president is taking us to war!!!  he did such great job in Afghanistan. he going to do it again"}
支持 2 反对 1
48
发表于 2022-2-22 21:12:47 来自手机 | 显示全部楼层
1280036 发表于 2022-02-22 13:10:38 If you’re a man you’re automatically guilty
","text":"You still crying 😭😭😭 Pam driver","replyToPid":459628}
发表于 2022-4-30 07:53:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lol 😂 i ride n a 2022 flat top pete n i run paper logs never been questioned about it ever ","replyToPid":0}
发表于 2022-2-22 21:52:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Qc crashes you reproduce your paper logs and roll. It adds up the same on the qc as it does on paper.. Be safe out there paper logs are not intimidating and you just gotta switch it over and go. Best of luck.","replyToPid":0}
发表于 2022-3-26 07:35:33 来自手机 | 显示全部楼层
936953 发表于 2022-03-25 15:51:43 It’s not the year of the tractor that matters. It’s the year of the engine …
","text":"I thought they changed the language on  that. I'm sure it's now frame.  no longer putting old engines in new frames?\nyou have to install the same or newer e.p.a. for year of chassis.","replyToPid":460923}
发表于 2022-3-25 23:51:43 来自手机 | 显示全部楼层
612134 发表于 2022-03-25 07:26:03 what if I have a 1999 tractor? 😁
","text":"It’s not the year of the tractor that matters. It’s the year of the engine …","replyToPid":460910}
发表于 2022-2-23 00:59:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes driving on paper is a violation, unless your electronic log broke. Then you have 1 week to fix it. There’s also a requirement to notify FMCSA and get permission to run paper.","replyToPid":0}
发表于 2022-3-25 15:26:03 来自手机 | 显示全部楼层
936953 发表于 2022-02-22 16:59:12 Yes driving on paper is a violation, unless your electronic log broke. Then you have 1 week to fix it. There’s also a requirement to notify FMCSA and get permission to run paper.
","text":"what if I have a 1999 tractor? 😁","replyToPid":459652}
发表于 2022-3-26 01:04:17 来自手机 | 显示全部楼层
","text":"They're both a 99 haha 👍\nBut yes you're correct.","replyToPid":460923}
GMT+8, 2026-3-21 09:14 , Processed in 0.293137 second(s), 24 queries .
