查看: 422|回复: 9
need advice
 楼主| 发表于 2022-2-13 22:17:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"I got a 99 Peterbilt 379 with a Cummins motor last night as I was pulling in a truck stop,clutch went almost to the floor I can move it with my hand all the way down to about 6 in from the floor any ideas what's wrong","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-2-14 10:28:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like pressure plates to me ","replyToPid":0}
发表于 2022-2-14 12:20:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trash it and get an automatic! ","replyToPid":0}
发表于 2022-2-14 10:19:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"If the clutch still engages, your return spring broke. Easy fix, get a new spring and install. If it doesn't engage, your pressure plate fell apart and you need a new clutch assembly.","replyToPid":0}
发表于 2022-2-13 22:39:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Time for a major clutch adjustment…","replyToPid":0}
发表于 2022-2-19 07:45:45 来自手机 | 显示全部楼层
1031233 发表于 2022-02-14 18:01:11 and have even more problems, automatics are junk !
","text":"autos are the only way to go.","replyToPid":459092}
发表于 2022-2-14 05:22:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"could be linkage","replyToPid":0}
发表于 2022-2-14 18:38:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trying to understand what relationship the Cummins motor has to the clutch issue?","replyToPid":0}
1万
发表于 2022-2-15 02:01:11 来自手机 | 显示全部楼层
842845 发表于 2022-02-14 04:20:51 Trash it and get an automatic!
","text":"and have even more problems, automatics are junk !","replyToPid":459051}
发表于 2022-2-15 08:41:58 来自手机 | 显示全部楼层
1432748 发表于 2022-02-14 16:37:17 check the fluid level first.
","text":"Maybe I should post all the questions you asked. Then you giving others advice 🤣🤣🤣🤣🤣🤣","replyToPid":459091}
GMT+8, 2026-4-16 05:14 , Processed in 0.144805 second(s), 24 queries .
