查看: 148|回复: 1
No Taillights
 楼主| 发表于 2022-2-10 11:35:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m pulling a refer trailer and my top marker lights work, my blinkers all work, my flashers work, brake lights work but my bottom maker lights and taillights won’t even flicker. Out of blue it did this. Any wiring wizards in here? Driving a 2006 T600 KW. Probably in my trailer wiring? Yes I’ve been through the fuses and relays and took apart the electrical plugs from tractor to trailer. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-2-10 12:12:00 来自手机
{"replyTo":"","text":"Get one of these, with it you can determine if it’s a problem with the truck, trailer, or cord. 7-Round Pin Trailer Circuit Tester 7865L https://www.amazon.com/dp/B000HI48KI/ref=cm_sw_r_cp_api_glt_i_CS16JBEWQ4V94DAKSWAT","replyToPid":0}
支持 3 反对 0
发表于 2022-2-10 19:23:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Prob a rub through or a previous repair that may have cracked/corroded between the trailer plug and rear.  Pending brand of trailer, we run Utility reefers and our issues all seem to be from where the wires/air lines meet at the bogies and continue to the rear lights.  \n\nJust my thoughts, hope it helps.","replyToPid":0}
GMT+8, 2026-3-22 18:54 , Processed in 0.067819 second(s), 24 queries .
