查看: 191|回复: 2
can I fix this myself?
 楼主| 发表于 2022-2-7 23:56:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"what's the rubber part called at the tail end of the cab fairing called? can I snap that back on my truck? ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":false,"externalShare":false}
发表于 2022-2-8 14:05:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"No dip cheet you can’t snap it back on. You snapped it off jack knifing your rig. See them holes that’s where the screws was that you popped off. Get a screw gun out and put about 6 in there hood as new","replyToPid":0}
 楼主| 发表于 2022-3-29 04:33:27 来自手机 | 显示全部楼层
1037330 发表于 2022-02-08 06:05:10 No dip cheet you can’t snap it back on. You snapped it off jack knifing your rig. See them holes that’s where the screws was that you popped off. Get a screw gun out and put about 6 in there hood as new
","text":"I snapped It back on thanks. use water , soap, an extra hand and a ply tool. no holes on my cab fairing preciate ya","replyToPid":458631}
GMT+8, 2026-2-6 21:22 , Processed in 0.071516 second(s), 24 queries .
