查看: 199|回复: 6
ifta question?
 楼主| 发表于 2022-2-5 05:04:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do any of you that run paper logs have automatic ifta tracking software? if yes.\nWill it be different than my logs that I have to (adjust)?    what does it show locations and times etc?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-2-5 05:27:59 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"One has nothing to do with the other. No one will ever be looking at both of them at the same time time. Paper will never match up to electronic, paper is 15 minute increments and electronic is by the second."}
发表于 2022-2-5 05:31:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here’s a chart of what’s required https://cdn.ymaws.com/www.irponline.org/resource/resmgr/about_irp/eld_5_23_17.pdf","replyToPid":0}
发表于 2022-2-7 11:22:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"wth is ifta?","replyToPid":0}
 楼主| 发表于 2022-2-5 05:36:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks one that I was looking at was showing location maps for everyday.\nmaybe that was an extra for that program?","replyToPid":0}
 楼主| 发表于 2022-2-5 05:40:33 来自手机 | 显示全部楼层
936953 发表于 2022-02-04 21:27:59 One has nothing to do with the other. No one will ever be looking at both of them at the same time time. Paper will never match up to electronic, paper is 15 minute increments and electronic is by the second.
","text":"thanks one that I was looking at was showing location maps for everyday.\nmaybe that was an extra for that program?","replyToPid":458500}
 楼主| 发表于 2022-2-5 05:41:24 来自手机 | 显示全部楼层
936953 发表于 2022-02-04 21:31:15 Here’s a chart of what’s required https://cdn.ymaws.com/www.irponline.org/resource/resmgr/about_irp/eld_5_23_17.pdf
","text":"thanks","replyToPid":458501}
GMT+8, 2026-4-17 13:34 , Processed in 0.086192 second(s), 24 queries .
