查看: 202|回复: 5
Passing Courtesies
 楼主| 发表于 2022-1-23 10:31:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"Certain Drivers when passing me in rainy or snowy weather cut too close and either spray my windshield or create a  heavy mist of snow. Cut too close is 5 feet clearance or less than 5 truck lengths. When passing give us 3 to 5 truck lengths before moving into the right lane, if you would please.\n\nPoint of contention. High beams signal an alert or a hazard. Do not use them as the signal for passing clearance is safe.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-23 12:29:47 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"One way to be courteous and avoid being offended when someone is passing you is maybe slow it down a few mph so they can pass easier and quicker, especially when there’s only two lanes and they have other cars and trucks behind them and are holding them up! Then after they pass you speed it up again! "}
回复 支持 5 反对 1
发表于 2022-1-23 21:57:54 来自手机 | 显示全部楼层
842845 发表于 2022-01-23 04:29:47 One way to be courteous and avoid being offended when someone is passing you is maybe slow it down a few mph so they can pass easier and quicker, especially when there’s only two lanes and they have other cars and trucks behind them and are holding them up! Then after they pass you speed it up again!
","text":"if I'm doing the speed limit and you decide to pass it's up to you to break the law to get by me not for me to slow down","replyToPid":457987}
回复 支持 4 反对 1
发表于 2022-1-23 12:01:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah truckers have no respect, most cut right over in front of me. 4wheelers leave more space than most inconsiderate truckers nowadays ","replyToPid":0}
发表于 2022-1-25 05:04:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Does anyone else think this sounds like See Here/ Timid Lady","replyToPid":0}
 楼主| 发表于 2022-1-24 07:40:15 来自手机 | 显示全部楼层
","text":"re-read my post, certain drivers create a traffic hazard with a disregard for traffic safety.","replyToPid":457987}
GMT+8, 2026-2-7 06:46 , Processed in 0.065278 second(s), 24 queries .
