查看: 392|回复: 10
Over weight on front tractor axle?
 楼主| 发表于 2022-1-22 13:49:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"I weighed in at a scale and my front tractor axle is 13,500 lbs? I’m trying to find a fix but they say moving the tandems won’t really help. Trailer axle is like 31,000 and back tractor axle is like 30,000 any advice?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-22 14:22:14 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"shaggy doo mom constantly puts my prevost overweight. you don't hear me whıne!\nslide the 5th wheel back like smokin said."}
回复 支持 6 反对 2
发表于 2022-1-22 14:00:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"The only solution is to slide fifth wheel to the rear of the tractor, or return to shipper.","replyToPid":0}
回复 支持 6 反对 0
发表于 2022-1-23 17:45:53 来自手机 | 显示全部楼层
1343306 发表于 2022-01-22 06:22:14 shaggy doo mom constantly puts my prevost overweight. you don't hear me whıne!\nslide the 5th wheel back like smokin said.
","text":"Bacooock!!!","replyToPid":457947}
1万
发表于 2022-1-22 15:15:41 来自手机 | 显示全部楼层
1235360 发表于 2022-01-22 06:27:44 I’m a rookie bro never dealt with this but I drive a 2019 cascadia and I can’t find a button to drain the airbags do I need to do it through the valve outside?
","text":"it's not about draining the air bags, can you slide your 5th wheel ? it is either a air slide or manual ? or it is a fixed 5th wheel...","replyToPid":457949}
发表于 2022-1-24 21:23:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I keep my 5th wheel all the way back just for situations like this. Also pull the cord that’s next to your air tanks and every morning break and when you fuel. It’s easier if you disconnect and slide that 5th wheel plate back. ","replyToPid":0}
发表于 2022-1-24 02:35:32 来自手机 | 显示全部楼层
936953 发表于 2022-01-22 06:00:07 The only solution is to slide fifth wheel to the rear of the tractor, or return to shipper.
","text":"another solution is make sure the tandems on your trailer are all the way back","replyToPid":457944}
发表于 2022-1-22 14:35:23 来自手机 | 显示全部楼层
","text":"yes the valve is outside","replyToPid":457949}
 楼主| 发表于 2022-1-22 14:27:44 来自手机 | 显示全部楼层
","text":"I’m a rookie bro never dealt with this but I drive a 2019 cascadia and I can’t find a button to drain the airbags do I need to do it through the valve outside?","replyToPid":457947}
 楼主| 发表于 2022-1-22 15:06:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nvm figured It out ","replyToPid":0}
GMT+8, 2026-2-7 03:44 , Processed in 0.096332 second(s), 24 queries .
