查看: 143|回复: 2
Heads Up: VA DOT cracking down on no-sign on-ramp parking
 楼主| 发表于 2022-1-22 01:58:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"Pulanski County especially but the Motel 6 on-ramp too in Staunton. No signs, and no litter at the ones I was at.\n\nI've been running NE out of NC the last three years and have done tens and thirties at both of these countless times. Within the last five months if I use a VA on ramp with no signs it's lead to a level 3 and forced move. This use to only happen in metros and places like MA, RI, ME, MD and the like...\n\nI believe non-driver entities in and around the industry think there is at least one spot open at least every other truck stop in every region. When usually rest areas and truck stops are usually packed out 1500 to 0900","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
禁止发言
发表于 2022-1-22 02:09:12 来自手机 | 显示全部楼层
发表于 2022-1-22 07:20:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for heads up yoyo ","replyToPid":0}
GMT+8, 2026-2-7 06:46 , Processed in 0.070469 second(s), 24 queries .
