查看: 371|回复: 9
Power Service 911 in the red bottle
 楼主| 发表于 2022-1-21 09:40:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"What does it do for your truck if you put it in but were not even gelled up. I’ve never done it but saw some dude putting it in his tanks at the fuel lane ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-21 22:11:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"911 red bottle doesn’t prevent gelling, at least that’s what the “Instructions” say","replyToPid":0}
发表于 2022-1-21 09:59:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Read the directions https://powerservice.com/psp_product/diesel-911/","replyToPid":0}
发表于 2022-1-24 12:40:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"it won't do anything harmful. if you're running in the sub degree weather use the white bottle the red is for more when your fuel starts to gel up on you","replyToPid":0}
发表于 2022-1-22 06:56:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"The power service in the gray bottle is an anti gel treatment, the 911 in the red bottle is to dump in after your fuel starts to gel or wax as some people call it. Power service didn't recommend using the 911 as an anti gel...     but it does absorb water in fuel like nobodies business.","replyToPid":0}
发表于 2022-1-21 20:55:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"He was using it as a preventative measure. If he was going somewhere really cold it will prevent gelling. Doesn’t hurt anything.","replyToPid":0}
 楼主| 发表于 2022-1-21 18:51:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bîtches ","replyToPid":0}
 楼主| 发表于 2022-1-21 10:47:26 来自手机 | 显示全部楼层
936953 发表于 2022-01-21 01:59:01 Read the directions https://powerservice.com/psp_product/diesel-911/
","text":"No","replyToPid":457883}
发表于 2022-1-22 06:08:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I only use antigens in the refrigerated trailers mainly because those fuel tanks are smaller and more exposed to the elements","replyToPid":0}
发表于 2022-1-24 21:35:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"O.O ITS RED…..HAS 911…..ON IT WITH AMERICAN ENGLISH INSTRUCTIONS. So maybe it’s for emergency purposes. Like if your fuel is gelling up that will unclog and remove the gell in a EMERGENCY. Lord common sense these days is far and between. ","replyToPid":0}
GMT+8, 2026-4-15 14:03 , Processed in 0.088822 second(s), 25 queries .
