查看: 528|回复: 10
portable jump starter recommendations
 楼主| 发表于 2022-1-19 04:07:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm in the market for a portable jump starter I can keep on me incase I ever need to jump start the truck and not stranded or paying loves to come out. \n\nHow many amps/cranking amps should the jump starter have? \n\nI don't think I need anything crazy as I doubt my battery will ever be completely dead but something powerful enough to give me the juice to power back up if the battery still is reading some volts.\n\nlet me know what you guys recommend. thanks","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-19 07:42:51 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Hardly believe there is any portable battery jump pack that can start a class 8 truck.  No way."}
回复 支持 5 反对 1
发表于 2022-1-19 08:30:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you pull a reefer hand if you do run u a hot wire from the reefer to ya batteries but do not connect it on either end till u need it you can charge truck batteries or reefer batteries ","replyToPid":0}
发表于 2022-1-19 07:25:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"heavy duty battery cables work great if you're pulling a refrigerated trailer","replyToPid":0}
发表于 2022-1-19 08:45:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"The VANAIR Start-All Jump-Pack will start any class 8 truck even with batteries that are totally dead. I start a 3406B four time in 0 degree weather and still had 75% charge left. It’s an awesome jump starter.","replyToPid":0}
发表于 2022-1-20 04:33:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Harbor freight has the 3400A 12V/24V portable jump starter $215","replyToPid":0}
发表于 2022-1-19 04:53:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"☝️☝️☝️☝️☝️☝️☝️💯💯💯💯💯😎😎😎😎","replyToPid":0}
发表于 2022-1-19 08:47:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sorry for posting twice ","replyToPid":0}
发表于 2022-1-20 09:10:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"The one we got from Matco has been decent ","replyToPid":0}
发表于 2022-1-22 03:55:59 来自手机 | 显示全部楼层
766797 发表于 2022-01-18 20:17:23 cheapest solution.....don't let the batteries go down; keep them charging klean dry should hold for 4 to 5 years ‼️🦕🦕🦕
","text":"Lol","replyToPid":457765}
GMT+8, 2026-4-15 14:02 , Processed in 0.118278 second(s), 25 queries .
