查看: 371|回复: 10
mechanics diagnostic
 楼主| 发表于 2022-1-19 00:22:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"hey guys i hope everybody ok , you guys have any idea about how much the mechanics charge for scan the truck ? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-19 04:48:26 来自手机 | 显示全部楼层
936953 发表于 2022-01-18 18:39:01 It’s an hour labor charge $75-$150 don’t listen to these $600 quacks. Any T/A can do it
","text":"☝️☝️☝️who’s the quack that’ll let the t/a touch their truck ","replyToPid":457755}
回复 支持 6 反对 0
发表于 2022-1-19 07:22:52 来自手机 | 显示全部楼层
1081791 发表于 2022-01-18 22:29:20 i will buy a truck and im trying to hice a mechanic to scan the truck and make sure everything is ok , but a guy in NJ charge 500
","text":"A pre purchase inspection is huge difference from a “scan” of the  truck. $500 is on par ","replyToPid":457787}
发表于 2022-1-19 02:39:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s an hour labor charge $75-$150 don’t listen to these $600 quacks. Any T/A can do it","replyToPid":0}
禁止发言
发表于 2022-1-19 00:28:11 来自手机 | 显示全部楼层
禁止发言
发表于 2022-1-19 00:29:47 来自手机 | 显示全部楼层
禁止发言
发表于 2022-1-19 00:52:54 来自手机 | 显示全部楼层
 楼主| 发表于 2022-1-19 00:38:33 来自手机 | 显示全部楼层
147103 发表于 2022-01-18 16:29:47 let me make suggestion. Buy your own scanner.  if your staying in trucking.  save yourself $$$ in long run
","text":"how much that cost","replyToPid":457742}
 楼主| 发表于 2022-1-19 00:39:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"tanks boss,  this guy in NJ charge 500","replyToPid":457741}
发表于 2022-1-19 05:11:14 来自手机 | 显示全部楼层
908202 发表于 2022-01-18 20:48:26 ☝️☝️☝️who’s the quack that’ll let the t/a touch their truck
","text":"It’s scanning codes, not rocket science. Jesus for a while some truck stops had scanners at the pump and you could do it yourself for $50","replyToPid":457775}
 楼主| 发表于 2022-1-19 06:29:20 来自手机 | 显示全部楼层
936953 发表于 2022-01-18 21:11:14 It’s scanning codes, not rocket science. Jesus for a while some truck stops had scanners at the pump and you could do it yourself for $50
","text":"i will buy a truck and im trying to hice a mechanic to scan the truck and make sure everything is ok , but a guy in NJ charge 500","replyToPid":457777}
GMT+8, 2026-4-15 14:03 , Processed in 0.059272 second(s), 24 queries .
