查看: 171|回复: 6
Help!!
 楼主| 发表于 2022-1-18 11:01:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi This app is good for navigation gps ? I will not get stuck in any clearance ? I buy RM tablet 85 2.0 but keep freezing and crashing they doenst work anymore I looking for altenative \n\nsmartroute2,copilot,hammer,truckpath","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-19 00:13:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't know about the clearance. But for truck routes, it's bad.","replyToPid":0}
发表于 2022-1-19 06:54:51 来自手机 | 显示全部楼层
1037330 发表于 2022-01-18 20:13:28 This app isn’t designed to be gps for truck drivers. A Garmin or Rand McNally gps helps but looking outside knowing where your going also a big atlas is better. If your dependent on this app to guide you, you will end up exactly where you don’t wanna be 99% of the time. It’s not hard to trip plan your route using a map. People been with out gps for 2000 years before wannabe driver
","text":"That’s so very D…amm true ","replyToPid":457764}
发表于 2022-1-19 04:13:28 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"This app isn’t designed to be gps for truck drivers. A Garmin or Rand McNally gps helps but looking outside knowing where your going also a big atlas is better. If your dependent on this app to guide you, you will end up exactly where you don’t wanna be 99% of the time. It’s not hard to trip plan your route using a map. People been with out gps for 2000 years before wannabe driver "}
发表于 2022-1-19 06:55:33 来自手机 | 显示全部楼层
908202 发表于 2022-01-18 19:23:37 Buy a freaking atlas driva
","text":"Amen to that answer ","replyToPid":457759}
发表于 2022-1-19 03:23:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy a freaking atlas driva","replyToPid":0}
发表于 2022-1-18 13:06:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Best app out here gold member ","replyToPid":0}
GMT+8, 2026-3-21 22:51 , Processed in 0.092593 second(s), 24 queries .
