查看: 708|回复: 22
being told to falsify logs and drive defective trailers, given loads impossible ETA I'm a rookie OTR, what would you do?
 楼主| 发表于 2022-1-16 03:04:28 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-1-16 03:45:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bring truck to terminal and quit.","replyToPid":0}
回复 支持 15 反对 1
发表于 2022-1-16 06:46:47 来自手机 | 显示全部楼层
1330928 发表于 2022-01-15 22:10:32 That’s the way our trucking companies are they called it a driver shortage I wonder why trucking companies are users and abusers.
","text":"Driver shortage is a bs myth.  The real shortage are companies that retain drivers.","replyToPid":457609}
回复 支持 11 反对 0
发表于 2022-1-16 09:20:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Document conversations with dispatch and drive that truck into the nearest open scale house and go from there.","replyToPid":0}
回复 支持 7 反对 1
发表于 2022-1-16 07:51:11 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"There are so many options out there. Don’t stay in a situation like that! There are good companies to work for. My husband is on his 4th co and is finally working for someone who cares about him. And makes decent money. We’ve been there,  change is hard but you have to be willing to keep looking to get where you want to be. Many stay in these situations because they believe they don’t have any options ! YOU DO !! Kiss a few frogs and you’ll find your prince. Good luck 👍🏼 try indeed and get a head hunter ! "}
回复 支持 8 反对 0
发表于 2022-1-16 06:10:32 来自手机 | 显示全部楼层
1372813 发表于 2022-01-15 19:45:40 Bring truck to terminal and quit.
","text":"That’s the way our trucking companies are they called it a driver shortage I wonder why trucking companies are users and abusers.","replyToPid":457605}
回复 支持 8 反对 0
发表于 2022-1-17 07:07:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Grown as men. coming on a forum. asking what do I do? I don't like my job. Guess common sense went out the window a long time ago.","replyToPid":0}
回复 支持 3 反对 4
发表于 2022-1-16 13:08:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"You are responsible for you ! Don’t let them make you mess up your life ! Look else where ! But no matter what don’t give up . We need help out here LOL 🤣","replyToPid":0}
回复 支持 6 反对 0
发表于 2022-1-17 05:35:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't violate your logs for nobody it is not worth having that on your record, bailing out on faulty equipment is the same, if all else fails have it towed back at the company's expense","replyToPid":0}
发表于 2022-1-16 14:45:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tell your boss you will drop the tractor trailer off at Banning Weigh Station in California then sue hisàrśe of being a bïtch. If he speaks tell him to shût the Füçk up until spoken to. Cover your bûtt. It’s your life rig responsibly to be safe. Find a better company. Don’t quit and don’t break your bàlls for anyone. ","replyToPid":0}
发表于 2022-1-16 08:44:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Quit","replyToPid":0}
发表于 2022-1-16 07:58:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take this job and shove it","replyToPid":0}
GMT+8, 2026-4-17 18:16 , Processed in 0.476375 second(s), 24 queries .
