查看: 165|回复: 6
Parking lots
 楼主| 发表于 2022-1-15 23:43:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"When u see flashing light (hazards, 4 ways, etc) USUALLY means someone is backing.\nBE FREAKIN PATIENT!!! ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-16 10:17:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t let them stress you out, it’s getting worse we just have to be patient & professional and slow & safe backing, I can’t believe how fast these drivers fly thru the truck stop just to go sit at the fuel isle smh","replyToPid":0}
回复 支持 11 反对 0
发表于 2022-1-16 15:52:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'll block the entire pathway until that driver is completely in the parking spot,  safety 1st,  I don't care if there are 1 or 20 trucks behind me","replyToPid":0}
回复 支持 6 反对 0
发表于 2022-1-16 14:49:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I see someone backing in a parking spot I park cut lights off. Take your time I’m never in a rush to blöw threw a truck stop. Also keep frozen water bottles. If someone try’s to run you over knock that windshield out. That’s attempt man slaughter in a commercial vehicle and your defending your self. ","replyToPid":0}
发表于 2022-1-17 12:59:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"All those want a b truck drivers thinks there better than we are till they need f…I guess help","replyToPid":0}
发表于 2022-1-19 04:26:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I seen a driver last night trying to back up at 2am. Another driver came flying in and started blowing his horn not letting the driver finish backing up. He was impatient disrespectful and waking drivers up. Also had his super trucker lights on shining in every one’s cab. He was mighty pissed off when I came in slow and blocked his was out. Drivers wanna put on a show like they tuff. Stand your ground. He got back in his cab when he seen that machete out the window. ","replyToPid":0}
发表于 2022-2-20 10:38:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Man when i hit the parkin lot i be creepin in one axle at a time n the low hole ","replyToPid":0}
GMT+8, 2026-2-7 01:59 , Processed in 0.069830 second(s), 24 queries .
