查看: 426|回复: 6
You guys that live up north, Do you leave your truck plugged in 🔌 at home when it’s below freezing
 楼主| 发表于 2022-1-9 05:27:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"Or just 12 hours before you are leaving to go back to work","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-9 05:34:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unless it’s below 0 F you’ll be fine. Just treat your fuel ","replyToPid":0}
发表于 2022-1-9 15:38:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I leave mine idling","replyToPid":0}
发表于 2022-1-12 10:09:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure to drain your air tanks and treat your fuel and you should be fine if it's not below 0","replyToPid":0}
发表于 2022-1-9 09:04:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"I plug mine in 24 hours before I leave out if it's 10 or below. The truck cranks and starts like it's summer..... so much less wear and tear on the engine.","replyToPid":0}
发表于 2022-1-12 05:10:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Come here I will plug in!!! I need recharge","replyToPid":0}
发表于 2022-1-12 06:33:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.mayoclinic.org/diseases-conditions/narcissistic-personality-disorder/symptoms-causes/syc-20366662","replyToPid":0}
GMT+8, 2026-4-15 14:10 , Processed in 2.361677 second(s), 24 queries .
