查看: 460|回复: 14
California compliance
 楼主| 发表于 2022-1-8 13:19:28 来自手机 | 显示全部楼层 |阅读模式
{"text":"Question I have a 2002 Peterbilt 379 and I want to go in to California but I know they have the emission \nCompliance . Can my truck go into California or not thanks In advance","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2022-1-8 13:42:57 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"No, the governor will seize it and send it to auction."}
回复 支持 4 反对 1
发表于 2022-1-8 21:33:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t know why you would want to go there but your good if your truck was a 2007 or newer and you removed the emission equipment then they’ll fine you. ","replyToPid":0}
发表于 2022-1-9 13:29:40 来自手机 | 显示全部楼层
1410714 发表于 2022-01-09 00:19:23 Have you been DOT at the scale
","text":"DOT inspector won't give you a problem. It is when a CARB inspector is there is when they give out tickets. Have had multiple DOT inspections over the years and never had a problem. I really would not worry about it.","replyToPid":457110}
发表于 2022-1-9 11:46:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"As long as you got a cat engine they will let u go    But Cummins they will send u to repair shop","replyToPid":0}
禁止发言
发表于 2022-1-9 08:41:23 来自手机 | 显示全部楼层
发表于 2022-1-9 04:19:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a friend lives in California has a fleet and he has deleted everyone and runs, so as long as your truck isn't smoking you'll be fine.....but there's always a risk","replyToPid":0}
发表于 2022-1-8 23:23:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"California has a lot of scales but I have never been bothered by any one ","replyToPid":0}
发表于 2022-1-8 23:04:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I know a guy that does it regularly, he says that there are lots of roads into California ","replyToPid":0}
发表于 2022-1-9 01:44:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"The scales don’t enforce emissions laws, that’s not their job. But I have witnessed CARB at the scales smog checking trucks with a sniffer up the tail pipe.","replyToPid":0}
发表于 2022-1-9 01:45:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"I ran  in CA quite a lot in a 2004 W900 and never had a problem or a ticket.","replyToPid":0}
 楼主| 发表于 2022-1-9 08:19:23 来自手机 | 显示全部楼层
925557 发表于 2022-01-08 17:45:06 I ran  in CA quite a lot in a 2004 W900 and never had a problem or a ticket.
","text":"Have you been DOT at the scale","replyToPid":457086}
 楼主| 发表于 2022-1-9 08:25:47 来自手机 | 显示全部楼层
1074173 发表于 2022-01-08 13:33:58 Don’t know why you would want to go there but your good if your truck was a 2007 or newer and you removed the emission equipment then they’ll fine you.
","text":"I really don’t want to Go to California But I just Got a dry van That  I need to pick up in San Diego and I’m at little scare.  I don’t wanna get ticket ","replyToPid":457061}
GMT+8, 2026-4-17 13:34 , Processed in 0.085258 second(s), 24 queries .
