查看: 405|回复: 21
Appalled
 楼主| 发表于 2022-1-6 06:33:46 来自手机 | 显示全部楼层 |阅读模式
发表于 2022-1-6 09:58:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can fix the issue! Don't get on here. Problem solved!!!","replyToPid":0}
发表于 2022-1-6 08:45:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"☝️💯💯💯💯💯🤮","replyToPid":456652}
发表于 2022-1-6 07:32:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Everyone hears you .........KAREN......🤣🤣🤣🤣","replyToPid":0}
发表于 2022-1-6 06:55:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why use it then??\nJust don't engage.\nduuuh.","replyToPid":0}
 楼主| 发表于 2022-1-6 07:08:49 来自手机 | 显示全部楼层
69015 发表于 2022-01-05 22:55:49 Why use it then??\nJust don't engage.\nduuuh.
","text":"You’re the one to talk you’ve got on just to say that it’s just like complaining about complainers complaining when you’re complaining you’re still complaining I mean the CB radios are worse but the censorship is even worse an posts an comment removals etc the forum is right there as equally as it is for you","replyToPid":456636}
 楼主| 发表于 2022-1-6 09:13:27 来自手机 | 显示全部楼层
908202 发表于 2022-01-06 00:45:48 ☝️💯💯💯💯💯🤮
","text":"I hated seeing them comment on those previous posts","replyToPid":456654}
 楼主| 发表于 2022-1-6 07:09:26 来自手机 | 显示全部楼层
655805 发表于 2022-01-05 22:55:20 It’s bad enough when they censor everything
","text":"They definitely don’t censor things I want them to censor things that I don’t want to see","replyToPid":456635}
回复 支持 0 反对 3
 楼主| 发表于 2022-1-6 08:22:45 来自手机 | 显示全部楼层
753289 发表于 2022-01-05 23:23:25 What don't you wanna see? Tell me so I'll know not to post it.
","text":"The gays mainly ","replyToPid":456642}
发表于 2022-1-6 06:55:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s bad enough when they censor everything","replyToPid":0}
 楼主| 发表于 2022-1-6 07:09:35 来自手机 | 显示全部楼层
","text":"You’re right about that","replyToPid":456635}
发表于 2022-1-6 07:23:25 来自手机 | 显示全部楼层
1280036 发表于 2022-01-05 23:09:26 They definitely don’t censor things I want them to censor things that I don’t want to see
","text":"What don't you wanna see? Tell me so I'll know not to post it.","replyToPid":456639}
发表于 2022-1-6 07:34:35 来自手机 | 显示全部楼层
1309412 发表于 2022-01-05 23:32:16 Everyone hears you .........KAREN......🤣🤣🤣🤣
","text":"Hahaha","replyToPid":456645}
发表于 2022-1-6 07:58:02 来自手机 | 显示全部楼层
","text":"☝️😂😂😂💯💯💯💯💯💯","replyToPid":456645}
GMT+8, 2026-4-17 13:34 , Processed in 2.391676 second(s), 24 queries .
